Hi there. I've recently been recording some stuff onto DVD using my DVD recorder. Usually to make copies of these, I would just make an ISO file and burn that to a new DVD, which is fine but for these, I was wondering if there was a way I could make the files smaller with minimal quality loss and be able to place multiple files onto a single DVD rather than the one. I managed to achieve this result by ripping the ISO to my HDD, using a program to convert the files to AVI and then used DVD flick to burn them to a DVD, however, the quality was pretty poor.
That is because you are expecting too much.Originally Posted by phenom
To go into a little more detail than hech54 did you can only go so small with a file size in a given codec before you lose quality.
Everyones perception is different of course so your tolerance may be different than mine and different from some guy down the street. BUT suffice it to say you can't cram say twenty episodes and convert them divx and except them to look exactly like the original dvd or broadcast quality.
Yes you can do pretty well but the more you to try shrink the file the worse the quality will look for a given video using a given codec with all things being equal. There are filters and stuff you can use to tweak videos but in the end you can only squish it so much before it breaks up and looks bad (especially using full resolution).Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
Creating a DVD Menu for multiple divx files without converting them
By LGT in forum Newbie / General discussionsReplies: 23Last Post: 21st Jul 2010, 15:04 -
converting multiple avi files to mgeg at once
By killagoob in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2008, 05:02 -
Problems converting Multiple .avi files w/ subtitles to DVD
By bwanis in forum MacReplies: 2Last Post: 30th Nov 2007, 14:23 -
Converting multiple files with convertxtodvd
By aruwin in forum Video ConversionReplies: 6Last Post: 29th Jun 2007, 05:27
