I'm using an AIW 9800 Pro with MMC 9.08. Capture works OK, including sound. A sound issue has been nagging me though. Whilst playing a video for capture, I don't hear the sound properly through the PC. This is with the input selector switched to "composite". Switched to analog tuner (ie for TV reception, not that I use the card for that), sound comes through loud and clear. I've tried all the suggestions I can find, altering Windows sound settings, connecting card output to sound card input etc.
According to the MMC 9.08 help files (and advice found on the net), MMC should include a "sound initialistaion wizard" as part of its initialisation wizard. But this just doesn't appear.
Anyone got an explanation?
Not correct. It's just Initialization Wizard, on one of the MMC setup tabs.sound initialistaion wizard
But that's still not your issue.
You don't have audio connect physically. Read this: http://www.digitalFAQ.com/forum/showthread.php/no-sound-ati-2292.html
Read that, look at images, do what it says.Want my help? Ask here! (not via PM!)
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 19:41 -
Capture ability on current ATI TV Wonder devices vs All-In-Wonder 9800 PRO
By vectorthom in forum Capturing and VCRReplies: 0Last Post: 17th Aug 2010, 20:35 -
Weird Interference ATI AIW Pro
By Tom Saurus in forum ComputerReplies: 8Last Post: 7th Aug 2010, 10:52 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
ATI AIW 9800 audio issue
By saggitarius in forum Capturing and VCRReplies: 1Last Post: 27th Jul 2007, 16:17
