Results 1 to 11 of 11
    Dec 2008
    Brazil
    Hello!
    My DVD burner that came with my Acer Aspire 5920 laptop is too slow for copying dvds. It copies around the 2.0x speed. When burning is more faster, but I'm searching if there are things that can speed up the read process, and I've found that some dvd writers have a riplock feature. I'd like to know if this dvd writer has this feature and if there are some way to unlock it?
    DiscInfo
    DISCINFO VERSION : 1.6.1.6
    VENDOR : HL-DT-ST
    MODEL : DVDRAM GSA-T20N
    REVISION : WP03
    VENDOR SPECIFIC :
    LOADING MECHANISM : Tray
    SERIAL NUMBER :
    NUMBER VOL. LEVELS : 256
    BUFFER SIZE : 2048KB
    INTERFACE : ATAPI
    RPC2 SCHEME : YES
    STATUS : Last Chance
    USER CHANGES : 1
    VENDOR CHANGES : 4
    CURRENT REGION : 4
    ANALOG AUDIO PLAY : YES
    COMPOSITE OUTPUT : NO
    DIGITAL PORT-PORT1 : NO
    DIGITAL PORT-PORT2 : NO
    READ UPC CODE : YES
    MULTISESSION READ : YES
    MODE 2 FORM 1 : YES
    MODE 2 FORM 2 : YES
    READ ISRC CODE : YES
    READ BAD CODE : NO
    BUFFER UNDER-RUN : YES
    MT. RAINIER : NO
    CAN READ CDR : YES
    CAN READ CDRW : YES
    CAN READ CDRM2 : YES
    CAN WRITE CDR : YES
    CAN WRITE CDRW : YES
    CAN TEST WRITE : YES
    CAN READ DVD-ROM : YES
    CAN READ DVD-R : YES
    CAN READ DVD-RW : YES
    CAN READ DVD-RAM : YES
    CAN READ DVD+R : YES
    CAN READ DVD+RW : YES
    CAN WRITE DVD-R : YES
    CAN WRITE DVD-RW : YES
    CAN WRITE DVD-RAM : YES
    CAN WRITE DVD+R : YES
    CAN WRITE DVD+RW : YES
    MAX CDR READ SPEED : 31
    MAX CDR WRITE SPEED: 24
    Also, I did a transfer rate test using "Nero CD DVD Speed", and the results are these:
    General Information
    Operating System Windows XP Professional (5.01.2600 Service Pack 3)
    Drive HL-DT-STDVDRAM GSA-T20N
    Firmware Version WP03
    Serial Number
    Disc DVD-R
    MID CMC MAG. AM3
    Capacity 1.34 GB
    Transfer Rate
    Start 1.71x
    End 2.67x
    Average 2.23x
    Type CAV
    Log
    Time Elapsed Action
    [20:12:30] Starting transfer rate test
    [20:20:24] 7:54 Speed:2-3 X CAV (2.23 X average)
    So, what should I do to fix this problem?
    thanks in advance!
    LG drives are infamous for this. Nothing to do. The laptop drives are crap. I have those, too.
    I use external Pioneer and Samsung drives, 16x USB2.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    My newer LG H58N is the same....slow ripper...fantastic burner. I even tried updating the firmware(that many say fixes the problem) with ZERO luck. I use an older LG 4167B to rip.
    Dec 2008
    Brazil
    wow... that's too bad.
    lordsmurf cited external samsung and pioner drivers as good ones. Any models that have a 'high' potential?
    Another question: as I see that my drive is ripping too slow, can this, in some way, advance the lifetime of the drive?
    thanks
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    1. Longevity of the drive is NOT the reason manufacturers make the drives rip so slow....just get that out of your head...
    2. My old LG 4040B (first reviewed by CNET in 2005) is still going strong - happily ripping(pretty quickly) and burning(@4x) in my old Dell backup computer....so drive longevity again is NOT a factor.
    If anything, running a disc at 2x for 30 minutes is worse than 5 minutes of 16x.
    Just pick any Pioneer 16x+ drive and you'll be fine.
  7. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    The speedtested DVDr should hold at least 4GB to make sense out of the scan result.
    *** Now that you have read me, do some other things. ***
  8. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    LG drives are famous for being slow rippers because they have the read speeds locked.
    Yeah, but even then, the drives are just not very good at reading or burning anyway, regardless of speed limits.
    Do you remember all the details on the limits?
  10. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    LG drives read speeds are locked at 6x speed which btw is good when you have a commerical dvd disc that's scratched. As for burning I haven't had any issues but then again my first LG drive was the LG H62L model. That model still works for me. But remember I used to be a dvd burner whore who has many different brands and models of dvd burners. I haven't really kept up with the dvd burner models since PIONEER began to use mediatek chipset & BENQ sold out their optical drive unit to LITEON. I been too busy in the world of overclocking cpu's!
  11. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Slimtype drive > slow and most times also unrelaible.
    Get a Half-height (desktop) drive if possible.
