Hi!
I have 12 AVI xvid videos that I need to trim the begining. I was told I can do this automatically with and avisynth script.
I don't know how to do that
The time to trim would be 1:30 (from frame 0 to 2158).
And how do I run the script?
Thanks a lot!
You want to keep the first 2158 frames or get rid of the first 2158 frames? Certainly, you can do either of those in AviSynth but you will have re-encode everything you keep. If you use VirtualDub's Smart Rendering mode you can re-encode only the cut GOPs.
To Script or Not To Script, that is the Question... (Custom Videos)
By TheMcD in forum EditingReplies: 2Last Post: 21st Oct 2010, 11:11 -
How do I create an AVS script
By Sopt Finder in forum Newbie / General discussionsReplies: 4Last Post: 15th Jun 2009, 14:17 -
Does my script look right? I am trying a new script
By rocky12 in forum Newbie / General discussionsReplies: 11Last Post: 25th Sep 2008, 20:10 -
how would i get a dvd video to run my autoplay script
By wan2no in forum Authoring (DVD)Replies: 17Last Post: 28th Jun 2008, 19:14 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36
