I have followed the instructions regarding hacking my 5990. My issue is when I get to the Preferences page, and type in the code, nothing happens.
This seems to work for everyone else, but not my machine. I've tried it with the tray open and the tray closed.
Any help would be greatly appreciated!!!
Did you check the firmware veresion? It's always possible there's a new version of the firmware and the hack no longer works. From one of the hack posts:
Verify procedure:
Open tray
Press 'Setup' button once
In 'General' page, press 1379
Firmware screen shows up displaying firmware version and region code in the bottom
Press 'OK' to exit
Some general guidelines: Make sure there is no disc in the drive. Start from a fresh power up. Don't wait too long between button presses. -
Yes, I did check it. BUT...after a few tries...it finally worked!!! Thank you for your response!
Philips DVP5990 Issue
By TheStranges in forum DVD & Blu-ray PlayersReplies: 3Last Post: 16th Dec 2010, 22:56 -
Philips dvp5990
By tqworld in forum DVD & Blu-ray PlayersReplies: 4Last Post: 18th Jun 2010, 17:24 -
[HELP] Philips DVP5990 and WD Passport Problems
By atoria in forum DVD & Blu-ray PlayersReplies: 6Last Post: 4th Jan 2010, 12:04 -
Philips DVP5990/F7 turned out ot be...
By toshik in forum DVD & Blu-ray PlayersReplies: 17Last Post: 4th Mar 2009, 22:36 -
Philips DVP5990 (80,60)
By hujercz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Dec 2008, 03:57
