Hello,
I'm trying to convert MKV file into AVI with the same size and quality using this programs Wondershare Video Converter Ultimate, Aiseesoft MKV Converter, WinFF and Avidemux but the result is not good at all.
The info for MKV file is:
Code:General Complete name :01.mkv Format : Matroska File size : 301 MiB Duration : 23mn 6s Overall bit rate : 1 824 Kbps Encoded date : UTC 2009-01-26 14:16:07 Writing application : mkvmerge v2.4.1 ('Use Me') built on Dec 5 2008 18:30:05 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video ID : 1 Format : MPEG-4 Visual Format profile : Advanced Simple@L5 Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : XVID Codec ID/Hint : XviD Duration : 23mn 6s Bit rate : 1 404 Kbps Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.191 Stream size : 232 MiB (77%) Writing library : XviD 1.0.2 (UTC 2004-08-29) Audio #1 ID : 2 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Codec ID : A_MPEG/L3 Codec ID/Hint : MP3 Duration : 23mn 6s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Stream size : 21.2 MiB (7%) Title : 粵語 Language : Chinese Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : A_AC3 Duration : 23mn 6s Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Stream size : 42.3 MiB (14%) Title : 日语 Language : Japanese
Best Regards,
SB4
You should be able to do this without re-encoding since the video stream is already Xvid. Extract the video and audio streams of your MKV file with MKVExtractGui and mux them into an AVI container with AVI-Mux Gui.
size avi, mp4, mkv
By hotsprout in forum Newbie / General discussionsReplies: 7Last Post: 18th Jul 2015, 13:25 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
my MKV converts aren't a descent quality for the file size
By devilfish in forum Video ConversionReplies: 4Last Post: 11th Sep 2011, 05:57 -
Is it normal? mkv to avi increase in size.
By Vitto in forum Video ConversionReplies: 10Last Post: 5th Sep 2011, 09:57 -
Trouble balancing quality vs size in MKV and MTS conversions.
By Omid in forum Video ConversionReplies: 4Last Post: 17th Mar 2011, 18:47
