Using the latest version (4.1 - 762), I'm stripping content from blu-rays. So first I read the blu-ray to an ISO image on the HD, then mount the image to virtual clone drive - all good.
I load up M-AVCHD, read in the BDMV folder, it scans it fine - my trouble comes when I'm moving through the titles deciding whether or not to blank the content. Each time I move from title to title, a delay occurs lasting about 30 seconds before showing information about the next title. Same thing happens if I slide the video positioner to another position - stalls about 30 seconds, then lets me continue.
Now, because this program does exactly what I need, I'm prepared to live with it if I must, but this hasn't always happened. This is a recent development, and I cannot think of any patches or changes that would cause it, other than upgrading to build 762 not too long ago, and I figured if that was the problem, many people would be mentioning it, and I've have a fix alreadyUninstall / reinstall no help. Also tried uninstall / reinstall of Haali - no help. Any suggestions?
Check this link: http://multiavchd.deanbg.com/downloads/
Open FFDSHOW Video Decoder settings and make sure (in Directshow Control) that multiAVCHD is allowed to use ffdshow, including avsinfo.exe, x264.exe, etc... Or just lift the restriction if it is set. It causes ffdshow to wait for 30 seconds, prompting the user if he wants to allow (avsinfo.exe for example) to use ffdshow.
DeanLaugh and the world will laugh with you. Cry and you will be alone -
OK, after fussing with this, I finally have it fixed - sort of, so I'd love an opinion on how to proceed next.
In the main how-to link you gave, installed the tester - all tested good
Made changes to FFDSHOW you recommended (adding the exe files you mention) no help
Removed all restrictions in FFDSHOW - no help
Downloaded the Windows7 tweaker mentioned in the main link (didn't have this before) - took all defaults, ran fine - no help.
Uninstall FFDSHOW / install newest version you have in your link - SUCCESS, but....
This newer version of FFDSHOW is not liked within BDRebuilder.
Uninstall FFDSHOW / reinstall older version that is accepted by BDRebuilder (20100319) - started to fail again in the same manner as before.
Sooooo...now I at least know how to get past this - makes it much less painful within blu-ray images that are 50+ titles long - but, short of uninstalling / reinstalling FFDSHOW each time I want to switch between BDRebuilder and multiAVCHD (sometimes having to use both back to back) - what would you recommend for resolving this problem? -
I think the difference is just with the installation defaults for ffdshow versions. Although BD-Rebuilder will work with ffdshow I recommend and multiAVCHD works with the one BD-Rebuilder recommends, I'd really hope that you can re-check if you really added avsinfo.exe, x264.exe, hx264.exe, mx264.exe, multiAVCHD.exe.
SUCCESS finally, so here's what I had to do, just so others who encounter this won't suffer so much
In direct show control, added all the exe files you mention (most weren't there - this setting was off by default), saved it, tested, no help.
In FFDSHOW in the codecs section - found that decoding for MPEG2 was disabled by install default - enabled to libavcodec (thanks to BD Rebuilder's inspector for detecting this) - saved, no help
Went back to direct show control, and unchecked the sneaky little option that says "show dialog when an unknown application tries to load ffdshow" - saved, SUCCESS
I'm still using FFDSHOW 20100319, now both programs are happy. Thanks for the time Dean
I'm glad you sorted it out.
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 02:03 -
Playing AVCHD "BD5" discs incl menus from MultiAVCHD on PC
By R.A.J. in forum Software PlayingReplies: 1Last Post: 5th Apr 2011, 10:44 -
"Alter Detected Properties" in multiAVCHD
By bmccollum in forum Authoring (Blu-ray)Replies: 2Last Post: 19th Oct 2010, 13:54 -
SOLVED!! - AutoMKV stuck on "parsing profiles"... (not respondin
By TooLFooL in forum DVD RippingReplies: 7Last Post: 3rd May 2008, 08:35 -
I'm totally stuck "unrecognised message" and other errors
By marinebc11 in forum MacReplies: 22Last Post: 26th Aug 2007, 17:32
