Dear friends, i have lot of .mkv(video=x264, audio=aac) files in which the subtitles(.srt) are already muxed. I want to extract the subtitle(.srt) from the mkv container without disturbing the audio and video quality. Once extracted the .srt file, i need to convert that into .smi file. After that mux the .smi to mkv container...
P.S: demux .srt from .mkv then convert .srt to .smi and mux .smi to mkv....
Get MkvToolnix. In a command prompt type
mkvextract --help
it will show how to extract streams.
For example if all your videos have one audio track and one .srt track, the .srt being the 3rd track you would use a command like:
mkvextract tracks movie.mkv 3:movie.srt
You could make .cmd file to do it in batch. If there's no spaces in the filenames then it's pretty easy:
mkvextract tracks %1.mkv %2:%1.srt
If the .cmd file was named GetSrt you would pass the above .cmd file the movie basename as in:
GetSrt moviename n
where n is the track number for .srt. If the .srt is always track 3 you can hard code it
mkvextract tracks %1.mkv 3:%1.srt
You'd end up with an .srt file with the same basename as the movie
If there's spaces in the filenames then I'd use a scripting language instead of batch. Just easier unless you're a .cmd wizard.http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
Convert sub to srt/smi/psb/ssa/ass/son with Subresync
By FireWalker in forum User guidesReplies: 14Last Post: 12th Jul 2019, 01:03 -
How to convert .smi to .srt ???
By longsasha in forum SubtitleReplies: 6Last Post: 28th Sep 2013, 13:43 -
Converting UTF8 subs to srt/smi/sub?
By Agrippa in forum SubtitleReplies: 7Last Post: 5th Jun 2013, 18:57 -
Linux: How to Convert .SMI file to .SRT
By chiappa in forum SubtitleReplies: 4Last Post: 30th Jan 2011, 04:10 -
.smi to .srt
By sarujin in forum MacReplies: 10Last Post: 7th Jun 2008, 06:17
