  1. Member lapetite_66's Avatar
    Apr 2006
    Hi:
    I just made an ISO DVD using Nero 7 ISO feature.
    After backing the stuff up I wanted to make sure that everything was on there and it was but there's a problem with the folders. I guess I should say that there is a problem with how the folder themselves look. (See Attachment) I even went back and got some of my old ISO CD's and DVDs and they all looked warped too. As for the stuff on my computer the folder (icons/image) are fine with no issue it's just the ISO discs.
    I recently had an issue with my computer and had to do an OS repair (virus or the fact that I had unplugged my computer for around four days and forgot about it...I was going to attempt to see if I could view my jacked-up Hitachi harddrive...but that's another story) I don't know if this is a problem with Nero or something else and frankly I am at a loss as to how to fix this problem.
    Thanks,
Name:	Nero Folder Issue 2.jpg
  2. That's normal for ISO files, you can associate ISO files with a program such as ImgBurn and get it's icon.
  3. Member lapetite_66's Avatar
    Apr 2006
    Moviegeek:
    That's how the files looked after they were saved to disc not before. Whenever I popped in a disc before and opened it the files looked like regular folders.
    I am not happy with the way they look now.
  4. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    They looked "warped" ??
    If all the information is there & accessible who cares how they look!!!
    Having the info/files there and being able to access them is whats important!!!
