8 years after, I have the same question, since my video player only likes 4:3 and 16:9.. is it possible to add black bars (source is either AVI-Xvid or MKV-x264) without reencoding?
The final format/container would be either AVI or MKV.
If reencoding is necessary, what would be the best tool to do this kind of job? (In case I'd reencode I'd use x264.)
Please do not use old threads,i have moved your post to a new thread.
Or get a better video player - I have yet to see one that cannot take avi or mkv files at any resolution and not be able to add the correct letterboxing or pillarboxing to fit 4:3 or 16:9m output. It is only when you are trying to author a DVD or AVCHD/Bluray that correct letterboxing or pillarboxing is required.
Read my blog here.
Thanks, but I don't think it's possible with Handbrake, for example. I tried it when I had it installed and also read this on a forum..
So before I try each of them and install all kinds of stuff on my PC (which I hate doing, but is required just to make one of those programs run) I'd rather have a confirmation from someone who did the exact same job.
need to correct Aspect Ratio by padding/adding black bars - author AVCHD
By texas1 in forum Authoring (Blu-ray)Replies: 3Last Post: 24th Nov 2011, 11:44 -
Back to the black bars
By Joolz2020 in forum Newbie / General discussionsReplies: 7Last Post: 19th Feb 2011, 08:02 -
Black Bars
By cinnamonhearts2 in forum Newbie / General discussionsReplies: 15Last Post: 30th Jul 2009, 12:44 -
black bars or not?
By Cowabunga in forum Video ConversionReplies: 6Last Post: 16th Apr 2009, 12:56 -
Autodesk Cleaner: adding letterbox black bars ("widescreen matte"
By sybariten in forum Video ConversionReplies: 2Last Post: 13th Mar 2008, 07:57
