Hello, I just edited some video that i have recorded of my friends wedding, and the raw video was 1920x1080 30p and my project render was 1280x720 30p.
My output file was .mt2 extension for high definition.
I am trying to use nero to burn it to dvd because I want to make chapters and create a dvd menu, but when i try to add the files to nero it wont work. Please help. Thanks.
What are you planning to use for playback? That resolution won't work for a regular DVD and set top player, so I assume you plan to author it to a Blu-ray player compatible disk?
And welcome to our forums.
EDIT: You might take a look to the upper left on this page for 'WHAT IS' 'Blu-ray' and 'DVD' for the specifications, format and structure of Blu-rays and DVDs. -
Thank you for your reply.
I was going to use the disc a playstation 3. Now that you point that out, I guess it wont work to burn these to dvd?
The only way would be to burn the dvd as a data disc and hope the player can read the file types? -
That's right. Unless you resize it to 720x480/576 and reencode it to MPEG-2, then no true DVD video for you. I have no idea what a Playstation 3 accepts, but burning it as a data disc is worth a try.
Thank you again..
For your reference, the Playstation 3 is equipped with a blu-ray player.
So I guess I will just make 2 versions of my video.
1. I will re-encode it as .mpg at 720x480 for DVD
2. I will just use my .mt2 files on a laptop and stream it via HDMI. Thanks for all your help! -
You could also look at multiAVCHD for creating AVCHD authored discs for burning onto DVD5s with Imgburn. The PS3 will happily play these, and you can have menus/chapters etc.
Read my blog here.
Green noise using MPCHC to play mt2 files
By Sackspud in forum Newbie / General discussionsReplies: 4Last Post: 9th Nov 2011, 12:24 -
Burning to DVD with VTS files
By cameraz in forum Newbie / General discussionsReplies: 5Last Post: 18th Nov 2009, 21:18 -
burning DVD files
By Itsmeshane in forum DVD RippingReplies: 2Last Post: 21st May 2008, 17:37 -
Burning several avi files to a DVD
By shashgo in forum Newbie / General discussionsReplies: 5Last Post: 10th Apr 2008, 09:23 -
burning video files to dvd
By brenjim in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2008, 18:41
