  1. Hi everyone,
    I need to upgrade my software, and I have less than a week to get something new.
    The software I need has to be able to edit down to these configurations.
    Can anyone help as to what I should buy??
    Many thanks
    Wrapper: MOV (QuickTime Movie)
    Video Codec: H.264 (MPEG-4 Part 10)
    Video Bit Rate: 2Mbps (Minimum)
    Video Frame Size: 720x576
    Video Frame Rate: 25 fps
    Video Aspect Ratio: 16:9
    Audio Codec: AAC (Mpeg-4 Audio)
    Audio Sample Size: 16bit
    Audio Bit rate: 160Kbps 48 khz Stereo (Minimum) Audio Bit rate: 256Kbps 48 khz Stereo (Maximum)
    Apr 2004
    Miskatonic U
    Platform ?
    Budget ?
    Capabilities ?
    Hell, with that description, you can use mpeg-streamclip, but I suspect you want something more than that. Details are what's missing from your post. You have given us nothing at all to go with. Start by describing what sort of editing you are doing, what features you need in your editing software, and what platform (Windows/Mac/Linux) you are working with. New hardware or old ?
    Read my blog here.
  3. Thanks for your reply.
    Budget? Anything goes!
    I'm using Windows Vista (32), can't tell you the exact spec of my PC (I'm at work at the moment) but it's new and fast (if that helps?)
    I'm uploading short videos to an ftp site for work. Fancy effects etc aren't essential, the compression is though.
    Does that help?
  4. As guns1inger has already suggested - mpegstreamclip will do what you need. Not expensive either (free!)
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    What is the source video format ?
    Read my blog here.
