possibly freeware
thanks
Results 1 to 10 of 10
An original as in a store bought pressed dvd ?
Or an original i created it myself dvdr ? -
Hey, it's a valid Q.....
An "original" pressed dvd is going to have copy protection on it and ImgBurn won't cut it......
It's amazing how people that have been around for years don't know how to be more specific or actually use the super secret search function or the top secret hidden tools section
Although you expect it from newbies.......
Here's what works for me 99% of the time for backups:
o I check the size of the original disc before starting the process to determine whether or not it will fit on a single-layer disc.
o Rip the disc to hard drive using DVDFab HDDecrypter (freeware). (If it's a very recent disc, the freeware version, which the author has decided to update to the newer encryptions after a delay from first issue, may not work for awhile. I wait.)
o If the resulting size fits on a single-layer disc, burn with Imgburn.
o If the resulting disc is too large to fit on a single-layer disc, shrink using DVDShrink, which will do it automatically. (Double-layer discs are so much more expensive than SL discs, I just never considered them to be cost-effective, so I don't use them.)
o Burn to disc with Imgburn.
Never had to use anything else. For that other 1%, nothing seemed to work and I just didn't make a backup.
Good luck -
WOW!!!!
your F'n brilliant!!!!!!!
Too bad you did not come up with that before this post.....
https://forum.videohelp.com/threads/324178-best-sw-to-copy-an-original-dvd-to-another-d...=1#post2007590
ERRR!!!!!!
LOL!!!
An expected clueless newbie save......
Gee... i almost feel like my hero hech54
LMAO!!!!!! -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 13:52 -
how to copy an original disc
By marlo in forum Newbie / General discussionsReplies: 6Last Post: 24th Feb 2009, 16:26 -
How Do You Identify Whether The CD You Bought On Ebay Is An Original Copy?
By Nitro89 in forum Off topicReplies: 9Last Post: 22nd Oct 2008, 06:41 -
Can I copy an original DVD to VCD?
By cxgcxg in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 05:50 -
How to copy the formatting of the original dvd subtitles
By jujuandhuhu in forum SubtitleReplies: 5Last Post: 12th Mar 2008, 22:33
