I'm currently trying to demux and remux an MKV file to switch the .dts audio to .ac3 in order to create an .iso in Avi2DVD but, and this is the first file that this has happened on, I continue to get a "Clipping detected, a 2nd pass will be necessary" message.
After the second pass is done and I remux the file and import into Avi2DVD, no audio stream comes up. I can't create the .iso file. The file plays fine on my computer in Zoom Player and/or VLC, but much like what would happen when I'd attempt to load an MKV w/ .dts audio, it never finds an audio stream but can successfully determine all of the other details about the video file.
Any ideas?
So zoom player and VLC can identify audio in the new mkv ?
There were changes to the mkv spec recently that includes audio header compression. avi2dvd probably hasn't been updated to reflect that, many software and hardware haven't been updated yet either.
You can either use older version of mkvtoolnix (4.0.0 or older) , or disable audio header compression in the settings -
It looks like the version of mkvtoolnix that I was using was 1.7.0. I've also noticed that another file that I've recently done the same thing to another MKV, both of which have nearly identical specs with the exception of the frame rates (one is 24 the other is 23.9xx). They both use 6 channel DTS audio and the second MKV loads fine in Avi2DVD.
I've just attempted to convert again in eac3to and the clipping message has come through again.
HCenc 2nd pass, what to do about: "*** INFO, adjusting average bitrate..."?
By jclampy in forum Newbie / General discussionsReplies: 14Last Post: 5th Jan 2012, 15:30 -
Joining HD MOV files from camera & saving as mp4; "Invalid Audio Stream"
By maskingtape in forum Newbie / General discussionsReplies: 30Last Post: 23rd Aug 2011, 13:30 -
VRD-MC3 "Copy Protection Signal Detected: Cannot Record"
By cmwalsh in forum Capturing and VCRReplies: 6Last Post: 14th Jul 2007, 12:03 -
Avi2DVD message when loading AVI...."DV DVI Detected"
By geek2330 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jun 2007, 08:05 -
"Cannot append segment...", "Mismatch detected..."
By Ygramul in forum Newbie / General discussionsReplies: 2Last Post: 14th Jun 2007, 12:32
