Hi, i have a .ts file, which it's audio has 24KHz intensity stereo coding, thus i cannot demux it. the audio can only be heard by VLC player and no other player plays me the audio. I want to demux this file so i can edit and convert it.
Is there a way to recode the audio stream? like say to a 48KHz sample rate? What should i do?
Thanks in advance
Thanks for you advice. i just tried BeSweet, but i don't know why each time i try to recode, the program stops working! this is the first few lines of the log file:
Do you know why that happens?BeSweet v1.5b31 by DSPguru.
Using hip.dll v1.19 by Myers Carpenter <myers@users.sf.net>
Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net).
Using lame_enc.dll v1.32 (8/8/2003), Engine 3.90 <http://www.mp3dev.org/>.
Manual Dynamic-Compression algorithm by LigH (author of WaveBooster).
Logging start : 08/07/10 , 12:42:03.
C:\Users\Administrator\Desktop\BeSweetv1.5b31BeSwe etGUIv0.7b4\BeSweet.exe -core( -input C:\Users\Administrator\Desktop\000.ts -output C:\Users\Administrator\Desktop\000.mp3 -logfile C:\Users\Administrator\Desktop\BeSweetv1.5b31BeSwe etGUIv0.7b4\BeSweet.log ) -ota( -fs 24000 ) -ssrc( --rate 44100 ) -boost( /b2=5 ) -lame( --scale 1 -p --alt-preset 128 ) -profile( ~~~~~ Default Profile ~~~~~ )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] | Input : C:\Users\Administrator\Desktop\000.ts
[00:00:00:000] | Output: C:\Users\Administrator\Desktop\000.mp3
[00:00:00:000] | Floating-Point Process: Yes
[00:00:00:000] +------ Shibatch -----
[00:00:00:000] | Source Sample-Rate: 24.0KHz
[00:00:00:000] | Dest. Sample-Rate: 44.1KHz
[00:00:00:000] | Attenuation : 0.0db
[00:00:00:000] +-------- BOOST ------
[00:00:00:000] | Algorithm by : Dg
[00:00:00:000] | Boost Factor : 5.0
[00:00:00:000] | Limit Factor : 0.73
[00:00:00:000] +-------- LAME -------
[00:00:00:000] | 'abr 128' preset is used
[00:00:00:000] +---------------------
[00:00:00:100] Stream error : Sync found after 17140 bytes
[00:00:00:226] Stream error : Sync found after 2889 bytes
[00:00:00:326] Stream error : Sync found after 4217 bytes
[00:00:00:479] Stream error : Sync found after 18567 bytes
[00:00:00:527] Stream error : Sync found after 11510 bytes
I'm using Windows 7 Ultimate 64bit on an Intel Core2 Quad Q8200 2.33 GHz with 4GB RAM. -
tsmuxer: "Some tracks not recognized. This tracks was ignored. File name:..."
Thus after demuxing, i only get the .264 file and no audio file.
i used mpchc, it has no sound and the video flickers at certain points. btw, it uses Haali Media Splitter while vlc doesnt.
Thanks for you help so far.
Need help demuxing a M4V file
By FulciLives in forum Video ConversionReplies: 1Last Post: 8th Aug 2011, 01:18 -
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 13:31 -
Demuxing a TS file
By carlmart in forum Video ConversionReplies: 17Last Post: 29th Jul 2009, 15:04 -
How to cut a TS file with Projectx without demuxing?
By Talayero in forum DVB / IPTVReplies: 2Last Post: 12th Apr 2009, 19:23 -
Demuxing mkv file for DVDlab
By harshest in forum Video ConversionReplies: 4Last Post: 22nd Mar 2008, 17:51
