  1. Hi all,
    I am using a Panasonic GS250 for shooting auto races and I am thinking of trying an external mic to see if it improves the sound of the cars and announcer but decrease the noise from other fans. What would be the best brand? Looking for something good under $100
    Thanks for any ideas...
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    http://www.kiva.org/about
  3. Hello,
    That mic sure looks good. I am wondering though will it let me hear the distant sound as I do not care for the close talking as I am 20 feet or more from the track? Does it have any kind of zoom feature where I can switch from close to distant? If not is there a really good mic that does?
    Thanks for any advice..
  4. Member edDV's Avatar
    Mar 2004
    The Rode has good overall sound quality for the money and favors the front direction over the sides or back. See youtube for demos.
    A good highly directive "shotgun" will be more expensive. You can find demos of these on youtube also.
    http://www.dvinfo.net/forum/all-things-audio/101434-best-shotgun-mic-200-400-a.html
    Note that many of these mics have XLR 600 ohm connectors and some need phantom power. You will need at least a matching transformer (Shure A96F) to use XLR with a consumer camcorder.
  5. Has anyone tried one of these:
    Audio Technica ATR6550 Condenser Shotgun Microphone
    Are they any good as it has a tele feature on it.
  6. Member edDV's Avatar
    Mar 2004
    See a demo here + mixed reviews.
    http://www.amazon.com/Technica-ATR-6550-Condenser-Shotgun-Microphone/dp/B002GYPS3M
    Also check the linked Azden models.
  7. Hello,
    I found that out as I did some more research on this and found it is not stereo either.
    Thanks..
  8. Hello,
    Has anyone used the mic below, it has pretty good reviews on both amazon and b&h site
    Azden SMX-10 Stereo Microphone
