Well my problem here is.
i put the plugin into the Plugins folder etc
Made my script which is
This script seems pretty good to me.LoadCplugin("C:\Program Files\AviSynth 2.5\plugins\AVSInPaint.dll")
Import("C:\Program Files\AviSynth 2.5\plugins\INPAINTFUNC.avs")
LoadPlugin("C:\Program Files\MeGUI\tools\avisynth_plugin\ColorMatrix.dll")
LoadPlugin("C:\Program Files\MeGUI\tools\dgindex\DGDecode.dll")
DGDecode_mpeg2source("C:\Documents and Settings\Administrator\Desktop\VIDEO_TS\VTS_01_1.d 2v", info=3)
ColorMatrix(hints=true, threads=0)
crop( 0, 0, 0, 0)
LanczosResize(720,400)
InpaintFunc(last, mask="screen.bmp", loc="ml", AR=16.0/9.0, mode="both", speed=20, ppmode=1, pp=75)
But i open VDUBMod
Try and open the script it says:
Avisynth Open Failure:
Not And AVISYNTH LOAD C PLUGIN: C:\ProgramFiles\Avisynth 2.5\Plugins\AVSInpaint.dll
C:\Documents and Settings\Administrator\Desktop\Myscript Line1
I Really need some help getting this to work.
I am using Avisynth Version 2.5
all my other plugins work fine.
Thanks in advance
Results 1 to 19 of 19
http://avisynth.org/mediawiki/Plugins
Not sure which DLL this refers to; but try putting the AVSInPaint.dll in another folder.Kevin provides a LoadCPlugin.dll that overloads the LoadCPlugin() verb to support plugins compiled using the C subroutine calling sequence, use Load_Stdcall_Plugin() to load stdcall calling sequence plugins when using Kevins version. Advice: keep these plugins outside your auto plugin loading directory to prevent crashes.Last edited by AlanHK; 4th Aug 2010 at 13:14.
Are you running the latest version AVSInpaint-2008.02.23.zip?
If you have the the previous version AVSInpaint-2008.01.06.zip, then you also need to put
LoadPlugin("AviSynth_C.dll")
before the LoadCPlugin call.
Or download the later version from
http://forum.doom9.org/showthread.php?t=133682 -
Ok, i retried that and that worked
but now it comes up with another error
it says:
Analyze: Mask Is Empty
Directory\INPAINTFUNC.avs, Line 304Last edited by tribal1965; 4th Aug 2010 at 18:26.
Is your screen.bmp in the middle left side? And does your screen.bmp consist of a true white area where the logo is, against a black background? Just using a pic taken from the video won't work.
If the answers are 'yes', You can also crop to it more exactly:
loc="68,54,-600,-388"#just an example
And the chances are very good that you don't need the Colormatrix filter. Are you reencoding for DVD? -
This is my screenshot:
as far as i know it's all black and white...
I Am re-encoding DVDR VOBS to encode to AVI File blurring subtitlesLast edited by tribal1965; 5th Aug 2010 at 06:35.
Does that look like ML (middle left) to you? Or, at 720x400 are you not including the entire thing? It's so big you'll have to use crop figures to get AVSInpaint to work correctly.
Ok, thanks for the reply, but i don't understand what you mean, i am trying to learn this plugin to be honest so if you could be a bit more simpler
Does it mean the pic can't be 720x400?
What do i need to put instead of ML?
also what am i doing wrong,
Thanks for replies it's appreciated. -
Hey,
thanks for reply i literally just noticed that about ML etc.
anyhow i need to know my specs of my white box
from the thread, my screenshot above how do i get them from my screen?example : loc = "0,300,-440,-20". Spaces are not allowed in "loc" parameter.
Thanks if someone could tell me
I make an AviSynth script, use ImageSource on it, open the script in GKnot and crop to get the crop values. You could do the same using VDub((Mod) to do the cropping. Because your logo is so large and spans 3 different locations (BL, BC, BR), you'll have to use crop values to get all of the logo removed:...my screenshot above how do i get them from my screen?
ImageSource("E:\2m7at0y.jpg")#adjust for your JPG location
And the crop values you plug into the Loc part of your InPaint script are loc="72,298,-112,-40". By the way, if this is a long video (more than 5 minutes, maybe), I'd trim off 500 frames or so to test first, to see if you like the results. This thing takes a very long time just to open (frequently as long or longer than the length of the video), and much, much longer to encode. And I've always used BMPs, but I guess JPGs are OK.Last edited by manono; 5th Aug 2010 at 18:17.
Thanks for the reply, i will give this a try now , my screenshot is .bmp but tinypic converted it
really thanks for your advice though -
Right,
i tried loc="72,298,-112,-40" on the avs script, and now it comes up with "Mask Is Full" -
My fault and I apologize. It's been a while since I've had to use the crops on a logo and I forgot that you can't crop right to the white part. Try loc="70,296,-110,-38". I tested it and it works. You might even want to leave more space around it, something like loc="68,294,-108,-36".
Finally i got it open
However, the blur seems to pretty poor to be honest....could anyone help me configure my script now?
so far the script is
The screens for Source and Would be encode here :LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\avisynth_c.dll")
LoadCplugin("C:\Program Files\AviSynth 2.5\plugins\AVSInpaint.dll")
crop( 0, 0, 0, 0)
InpaintFunc(last, mask="C:\Program Files\AviSynth 2.5\plugins\screen.bmp",loc="68,294,-108,-36", AR=16.0/9.0, mode="both", speed=20, ppmode=1, pp=75)
Source:
Would be Encode:
So anyone know how i could edit my script? sorry i am really new to this plugin
I really want a neat blur, else i would of just used logoaway
I don't know that you'll be able to get anything better than logoaway. That mask is just so big. However, you could back off the cropping some more (maybe subtract 4 more pixels from each number) at the expense of even longer encoding times. And it looks like your mask doesn't cover all the subs on the right side since there's a piece of a letter left. Maybe back off the right side crop by 10 pixels. And the PP should be 100. It'll become more blurry, but with those weird lines being less prominent. Also, your AR after the resize is no longer 16.0/9.0 but 1.0/1.0. But that won't make much difference. Also, it wasn't designed to do what you're trying to do. Instead of a constant logo in place for the entire movie, you have a 'logo' that constantly shifts around and changes size and sometimes isn't even there. InPaintFunction isn't really what you want to use. In fact, any logo remover will only create a nasty looking blur. Get the movie without burned in subs.
AH ok, i apreciate all the replies then....is their a good blur filter to remove subtitles, ive saw a couple people do this in the past, and the blur looks brilliant. just don't know what scripts/filters they use, it's definetly not logoaway....
I haven't had much practice removing hardcoded subs from downloaded movies because I don't download movies with hardcoded subs. Do you know how to use Logoaway properly:
http://www.voidon.republika.pl/virtualdub/ladocs301/logoaway.html
If it's a blur you want, it can certainly make a blur. There are other logo removers available, both AviSynth and VDub filters. Try them all. My opinion, though, is that it isn't worth the effort.
YAAI help needed
By snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 24th Apr 2011, 05:18 -
AviSynth much needed help!
By dbanimal in forum EditingReplies: 18Last Post: 28th Jan 2011, 10:33 -
HELP!! New Camera Needed
By hhouser in forum Newbie / General discussionsReplies: 1Last Post: 8th Nov 2010, 05:05 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
