Hello all. So, I have an MKV file with two audio tracks, Russian and English, with the former being set as the default track. This original file plays fine in both VLC and QuickTime (with Perian). I use ReduxEncoder to burn MKV files to DVD, but since Russian is set as the default audio track for this particular file, as you can imagine, the burned DVD outputs Russian audio. Hence, I decided to use MKVToolNix to remove the Russian audio track. The resultant file (English track only) plays fine in VLC, but in QuickTime, there is only a green screen, and what's more, ReduxEncoder won't burn the file. FYI, I am doing all of this on a Mac. Any ideas as to what went wrong?
	Just a guess, but try with version 4.0.0 , or disable audio header compression in audio settings
 Recent changes have introduced compatibilities with some players (hardware and software) , and they require updates
  Avidemux 2.5.6 Green screen problemBy ABBrittain in forum Newbie / General discussionsReplies: 0Last Post: 28th Feb 2012, 07:49
  VLC player not playing MKV fileBy GLE3 in forum Software PlayingReplies: 3Last Post: 15th Feb 2009, 16:39
  Possible issues with QuickTime 7.5 & PerianBy ffooky in forum MacReplies: 4Last Post: 11th Jun 2008, 14:27
  Best Aspect Ratio playing .mkv video via VLC/Quicktime for viewing on HDTVBy iMacMan in forum MacReplies: 4Last Post: 19th Feb 2008, 02:04
  Try Perian 1.0 for your mkv conversionsBy BeardFan in forum ffmpegX general discussionReplies: 22Last Post: 18th Sep 2007, 18:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
