AVCHD from Canon Camcorder. Clips work fine in Premiere.
Used TSSniper to cut the clip (no re-encoding). Somehow, many cut clips no are no longer aligned at frame boundary in Premiere.
What could cause it? If it's due to TSSniper, any other software to use?
Thanks!
AVCHD and HDV formats are MPeg. Both record with half second GOPS (15 frames NTSC, 12 frames PAL). To edit tighter than a half second you need a native MPeg frame accurate editor. These editors decode the GOP to frames, allow an edit, then reconstruct the GOP.
http://www.kiva.org/about
AVCHD in Final Cut Pro: am i doing it right ?
By stacks in forum Video ConversionReplies: 1Last Post: 8th Sep 2010, 06:07 -
AVCHD frame rate help.
By Rii in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 13th Aug 2010, 22:11 -
Looking for software to use as an AVCHD frame cutter
By sebaz in forum EditingReplies: 2Last Post: 19th Sep 2009, 15:29 -
How can I edit (cut) segments from a H264 AVCHD video without re-rendering?
By kmmoore in forum EditingReplies: 5Last Post: 14th Dec 2008, 13:51 -
What Video editor's can cut frame by frame?
By VEBouto in forum Newbie / General discussionsReplies: 19Last Post: 28th Oct 2007, 02:31
