  1. Hello,
    Currently I have a Panasonic SC-BT300, which comes along with a Blu-Ray player capable of decoding Dolby TrueHD and DTS-HD Master Audio. To test these audio decoding capabilities and to "feel" the lossless audio first hand, I downloaded some sample files with TrueHD and/or DTS-HD MA.
    Then, I used tsMuxer to create a AVCHD Disk and burned it to a DVD+R using imgburn at slow speed.
    ---###Now, The Problem###---
    When I place the recorded disk, the player recognizes the disk as avchd AND the TrueHD or DTS-HD MA tack audio. However, the playback of the video and audio is very choppy. What could be the issue?
    Is it simply that an avchd dvd+r does not support the lossless audio tracks or something else?
    On a side note, the player plays/decodes regular DTS or Dolby Digital Plus audio just fine, along with smooth video. I posted this thread after failing to find a definitive answer after searching Google and other forums
    Thank You
  2. Originally Posted by laxmandev View Post
    Hello,
    Thank You
    Does anyone have an answer to the question?
