Which is the best and simplest way to add a watermark to a DVD?
I produced/directed a documentary which I will now be sending to several film festivals around the world. So I would like to add my production company's name on the DVD's screen in a non-invasive way.
Of course the final copy, after selection, would not have any marks on it.
How can I do that?
Carlos
Results 1 to 9 of 9
If you know how to frameserve out of VirtualDub to an encoder like TmpgEnc then I'd recommend VirtualDub. People here seem to mention PNG files as being better than JPEG or Bitmap images for watermarks. AviDemux also has a built-in logo plugin AND AviDemux can output directly to MPEG on it's own(use the MPEG-PS output option).
How did you edit the original documentary? Use that same software to key your logo. Or, as an option, make your watermark a subtitle text. It won't be embedded into the actual movie, but at least you won't need to re-encode the m2v file.
Better yet--if all the footage and project files are still in the editing computer, you can just output the movie again, this time with your logo added. If the m2v file is all you have, virtually any video editing software is capable of keying a logo.
There are lots of options, but we cannot offer specific instructions until we know what materials are still at your disposal. -
This was edited in Avid Media Composer, and I don't want to go over the export process again for this logo.
I wouldn't mind if there was a slight deterioration on this DVD with watermark, as that would diminish the chances of it being used for unauthorized broadcasting. -
If all of the assets are still loaded in the editor's computer, it would require very little effort to export a new m2v file with the logo. Of course, if you have to reload footage and such, it would not be worth it.
Just make sure you think like a film festival judge before you submit. You'll be throwing away entry-fee money if you don't put your best foot forward.
Also keep a realistic view about watermarks. If people really want to copy your work, they will (blurring out the logo bug), regardless.
Good luck.
Adding watermark to video
By Shaorin in forum Newbie / General discussionsReplies: 2Last Post: 29th Nov 2010, 09:08 -
adding watermark as a subtitle
By zammil in forum SubtitleReplies: 8Last Post: 20th Nov 2010, 00:45 -
adding watermark to videos
By zammil in forum Newbie / General discussionsReplies: 7Last Post: 16th Nov 2010, 22:19 -
adding watermark while ripping
By rippergreat in forum Newbie / General discussionsReplies: 29Last Post: 13th Oct 2009, 09:05 -
adding watermark on video
By 3390 in forum Newbie / General discussionsReplies: 5Last Post: 27th Feb 2008, 05:13
