I have an Analog Cable TV signal which needs to be transmitted to a HD Monitor. So far I have been using the following setup:
Analog Cable RF Input --> LCD TV Tuner --> Output [VGA] to LCD HD Monitor
But the signal is worse & hence I wanted to use a DVB STB [CISCO Z255DVB-NM] available here in India as per my friend's advice. I tried giving the Analog RF input to the DVB STB box & the Cable Output to the TV tuner [and then to the monitor via VGA] but I do not get a TV signal. Is there a problem with the setup? I tried to use the RCA output to RF Input to the TV tuner card but no luck. Any ideas would help me a lot.
Results 1 to 1 of 1
Connect LCD monitor to Digital HD Cable box?
By rogerconnery in forum DVB / IPTVReplies: 84Last Post: 18th Jan 2012, 07:04 -
How would I connect my standard cable box to my HD LCD monitor?
By Jadedrain_06 in forum Video ConversionReplies: 4Last Post: 27th Nov 2011, 13:00 -
Dell 22INCH LCD MONITOR TO HD CABLE BOX
By Ashypoo19 in forum DVB / IPTVReplies: 3Last Post: 1st Apr 2010, 01:48 -
Hooking up an LCD monitor to Verizon Fios cable box
By JKam2000 in forum DVB / IPTVReplies: 2Last Post: 2nd Oct 2009, 02:41 -
TV Cable to LCD Monitor
By Cypha22 in forum Newbie / General discussionsReplies: 7Last Post: 15th Jul 2007, 17:40
