Need help to make my Sony BDP-S470 bluray-player region free for dvd playback! Have searched the web but can't find any solution.
Please tell me it is possible![]()
Sony DVD and BluRay players are currently among the most difficult in the world to unlock for region free DVD playback. There probably is not an unlock code for your player and that's why you can't find one.
Thanks for your answer...
It was pretty much what I feared. Hope they manage to crack them soon though. Region codes are stupid. -
A solution has been found : https://www.videohelp.com/dvdhacks/sony-bdp-s470/10830
If somebody knows where to find this remote control in the US, let me know. -
Hi,
I just bought a Sony BDP-S470 (in Europe) and I desperately need to make it region free (for dvds). So I found the instructions on this site (https://www.videohelp.com/dvdhacks/sony-bdp-s470/10830), and bought a One4all URC 3940 remote, but I seem to have a problem. I used the code 20533 to begin, exactly as it says, and then the rest
but my player is not responding to the remote at all, not when I press "power" or anything.
The oneforall works with my TV, so it's working. I thought it could be the player, so I installed the last update, no change. Could it be something in the system settings or something ? I could try and buy the OneForAll URC-7950, but someone said it worked fine with the URC 3940. Please help me.
Thank you.
Sometimes hacks break because of hardware changes by the manufacturer. This could be your problem. Or perhaps you'll get lucky and someone will post a solution that does work for your player.
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 16:12 -
how to unlock region free SONY BDP-S1
By alexgagliano in forum DVD & Blu-ray PlayersReplies: 4Last Post: 23rd Jan 2010, 12:34 -
region free for sony BD player BDP-S1
By alexgagliano in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Jan 2010, 14:31 -
sony BDP BX1 region free code
By eddybear in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Jan 2010, 20:51 -
looking for region free for sony bdp-s500
By 123groper in forum Blu-ray RippingReplies: 1Last Post: 29th Jul 2009, 09:23
