Hi im new here because im in real need of help.
Im trying to embed subtitles into a AVI file with ffmpegx with no luck.
and your help is GREatly appreciated!
Im using ffmpegx and it seems my AVI file is unrecognized and when the encoding is done the subtitle (srt file) is NOT embedded in the video.
i am very frustrated can anyone help me?
Results 1 to 14 of 14
I've never used ffmpegx so i cant help you with that, but this couple of days i have done some srt embedding to avi with virtualdub using plugin textsub 2.23 (from vobsub223), and it cant be easier than that.
Load avi, set audio direct copy, video full compression(or smart rendering ?) and choose the codec you want(tweak the compression settings), add video filter textsub, load the srt, set the style/font size-position/color.. you want, and save as avi.
pirej: ffmpegx is a Mac OS X program.
The OP probably won't be able to use VirtualDub on a Macbook.
I am using ffmpegx but it will not upload the subtitles at all, i go into the filters tab but nothing happens when i press encode. im so frustrated
To get subtitles (hardcoded, as part of the video) in an AVI file with ffmpegX, you need to use a mencoder preset, e.g. "XviD mencoder" (screenshot).
Did you unzip the downloaded file and use the Locate buttons to point to the binaries inside the unzipped folder?
Please see this post about the same issue.Originally Posted by sablerage
Note that mpeg2enc is not essential for the conversion you are doing now, as it is only used for encoding to MPEG-1/MPEG-2.
How to embed .ASS subtitles into video image?
By lordsmurf in forum SubtitleReplies: 1Last Post: 27th Nov 2011, 22:03 -
Possible to embed 'optional' subtitles to a video file?
By Apollonas in forum SubtitleReplies: 4Last Post: 5th May 2010, 12:05 -
Embed subtitles onto video
By Burnerneil in forum SubtitleReplies: 2Last Post: 20th Aug 2009, 14:30 -
how to embed subtitles?
By stlolth in forum SubtitleReplies: 6Last Post: 7th Oct 2008, 13:15 -
how to embed subtitles in a video?
By mai_hnf in forum DVD RippingReplies: 1Last Post: 1st Sep 2007, 21:22
Not even an error message! I think perhaps mencoder and mplayer are missing or weren't installed correctly.
