Hi - I'm hoping that someone can help me fix some quicktimes that have corrupt headers. I'm pretty sure this is the problem - they are photobooth videos that became corrupt when they were saved. I've looked at the aero quartet (http://aeroquartet.com/) service and it shows good screen shots and says it can be fixed for a price. I've got lots of these files though so this is going to get expensive!
I've also tried opening the quicktime in Dumpster, but for the corrupt file dumpster just sits on spinning wheel forever and it never opens.
So, my next try is to replace the header from a good movie using Hex edit - but I'm not exactly sure which bits I should be replacing. If anyone could advise it would be most appreciated.
Thank you!
Results 1 to 1 of 1
I can't edit this mov quicktime file
By qisheng in forum EditingReplies: 19Last Post: 1st Dec 2009, 03:05 -
can you edit the header of an mpg file
By lmwashere in forum EditingReplies: 9Last Post: 13th Nov 2009, 21:07 -
Extract Image from WMV using HEX values?
By phatz in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2009, 14:44 -
Hex editing time in .AVI files.
By ShadowShinobi in forum DVD RippingReplies: 3Last Post: 22nd Jan 2008, 13:22 -
How to edit MP4 header frame size?
By Darney76 in forum Portable VideoReplies: 4Last Post: 7th Jan 2008, 21:58
