I've backed up a movie using Mac BluRayRipper Pro. I tried burning with Toast 10 from the Video tab and BDMV folder option. That didn't work when I put it in 2 players. It told me that I needed to upgrade the software on my player.
Do I need to use ISO 9660? I'd play around with it and not mind the coasters...if the discs weren't $15/disc.
Any advice on how to burn these to play in my players?
Bluray are formatted UDF, I believe. You're correct about the price of discs. A BD-RE is a wise investment at this juncture in the game.
Price of BD-R disks have gone down considerably. I can find them now for about $3 apiece. My recommendation is to have just afew of the re-writable to use to test the compilation, then do a final burn on the BD-R.
Not all blank blu-ray disks are created equal. Your players may just not like the brand of disk you are using. I have great success with Verbatim. Very good prices on rima.com.
Also, some players may have difficulty playing burned blu-ray disks. A former co-worker's Sharp Blu-Ray player would not play disks that my Sony PS3 and Panasonic BD60 would play.TANSTAAFL -
Where are you getting 50GB BD-Rs for $3??!!!!
Price aside, is UDF the way to go? -
Best way to view a Ripped Blu-ray
By PHNeedsHelp in forum Blu-ray RippingReplies: 5Last Post: 1st Feb 2012, 22:24 -
Q: about playing a ripped blu-ray
By raptor1015 in forum Software PlayingReplies: 1Last Post: 29th Jun 2010, 11:58 -
Subtitles on a DVD from ripped Blu Ray
By fjmr in forum Blu-ray RippingReplies: 4Last Post: 27th Sep 2009, 07:49 -
BLU-RAY Ripped
By pensioner in forum Newbie / General discussionsReplies: 7Last Post: 11th Feb 2009, 22:37 -
Burning Blu Ray from ripped Blu Ray
By ppurdue in forum Blu-ray RippingReplies: 10Last Post: 15th Oct 2008, 19:51
