Not all motherboards support optical drives on the SATA ports, the same with onboard RAID controllers and most PCI IDE cards (it's mentioned in the manual). Usually, if the motherboard has a mix of IDE and SATA ports it won't support SATA optical drives; except for boards with Intel chipsets. Newer boards with AMD chipsets (with hyper transport chipset) work better. Best would be to google the your board or chipset and drive combo.
There are bi-directional SATA-IDE converters, you plug it into an IDE drive and the SATA port goes to the motherboard or you plug it into the motherboard's IDE port and you can add 2 SATA drives.
Results 31 to 32 of 32
Purposely I got a mother board with Intel chipset because I knew about the optical drive issues with other chipsets. Interestingly the link given is the exact same adapter I have that doesn't work. The IDE CDRW drive isn't seen in bios which I expected, but there's no screen showing the CDRW drive during boot either. I actually have 2 very similar PCs with Intel motherboards, and the adapter doesn't work on either one.
esata & sata adapter
By neworldman in forum ComputerReplies: 17Last Post: 31st Dec 2010, 20:08 -
IDE and SATA
By HotDamn! in forum DVD & Blu-ray RecordersReplies: 11Last Post: 6th Mar 2010, 00:49 -
sata vd ide
By dymx in forum ComputerReplies: 3Last Post: 9th Sep 2009, 08:04 -
Sata v.s IDE
By tapal in forum ComputerReplies: 4Last Post: 22nd May 2008, 05:04 -
IDE to Sata adapter....
By kenmo in forum ComputerReplies: 4Last Post: 2nd Apr 2008, 13:11
