Any way to transfer recorded video from Comcast DVR to DVD with my Mac?
Will Roxio's Easy VHS to DVD Capture work or is there similar software available?
thanks
THE TRUTH IS OUT THERE!!!! ---FOX MULDER
Analog out (S-Video plus analog audio) capture to any edit/DVD author program.
http://www.kiva.org/about -
If you want high def you can use the hauppauge hd pvr to record component and fiber optic from your cable dvr. HOWEVER I do not know if it is mac compatible. I have one but I am running Windos Vista Home Premium 32bit.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
A Mac is a disadvantage in this case.
If you had access to a Windows machine, you could use CapDVHS and copy the video over the firewire port. No reeconding would be needed for SD video. Just put the copied videos in a dvd authoring program and burn. HD programs would need to be downsized and encoded for DVD. -
The Hauppauge HD PVR works with Leopard and Snow Leopard via EyeTV. The EyeTV software recognizes the box as a valid input device. You can record high definition content via analog with it, and the transfer will be in H.264 with either an AAC audio track or a Dolby Digital one if you're using an optical connection for the audio portion of the program. Incidentally, it ignores the latest Macrovision protection placed on content from the Comcast On Demand service.
You can also capture unencrypted MPEG2 transport streams direct from your Comcast DVR as long as the FireWire input is active. In my area, Comcast has decreased the number of boxes they distribute with FireWire ports on them. -
Not only that, they are trying to recover the older boxes that have firewire on them. A few months ago they sent me mail warning me of the horrors that would happen due to a change in their service and that (gasp!) I might not get some channels unless I had one of their new boxes. I wasn't fooled and my old box, with firewire, worked fine after the change. I saw on my caller ID box that they tried several times to call me while I was at work, but now they seem to have given up.
My first post: connrccting a DVD to a comcast DVR to record from ther DVR
By retired_guy in forum Newbie / General discussionsReplies: 10Last Post: 24th Jul 2011, 18:54 -
Moto DVR DCT3416 from Comcast - can I get the recordings off the DVR?
By jmkeuning in forum Capturing and VCRReplies: 42Last Post: 7th Jul 2010, 17:44 -
Help hooking up Panasonic DVD recorder to Comcast cable HD DVR
By KeithJFro in forum DVD & Blu-ray RecordersReplies: 10Last Post: 22nd Feb 2010, 16:17 -
By KeithJFro in forum Authoring (DVD)Replies: 2Last Post: 22nd Feb 2010, 14:20 -
Recording a game from a Comcast DVR to a DVD recorder
By ConfusedinSC in forum DVD & Blu-ray RecordersReplies: 2Last Post: 17th Dec 2008, 12:18
