Two questions here: I've got Nero 5.5. What's the best way to duplicate a chaptered (or any) VCD to another CD-R disc? Also I'd like to copy another un-menued VCD to my hard drive so I can re-use those MPEG files to create another VCD with chapter/index. I have already erased all the original MPEG/AVI files from my hard drive (to free space).
well.... i can answer your fist question. put the vcd in your cdrom, a blank in the burner, and use the CD-COPY function in Nero. that is the easiest way.
-mark -
Here is a bit of the read me for you. I don't remember where exactly I found this but you should be able to do a search. Hope it helps...JimJohnD
MPEGTool version 1.04 Written by Dino
This program has 2 functions: one is to truncate a DAT format MPEG file into a MPG format, the other is to cut any portion of a MPEG file. Just follow the screen, select source and target file, give start and end frame number, then everything will be done automatically. Some DAT file
may become unreadable after truncate, check the 'Special format' radio button on page 2 may fix this problem.
This is a freeware, use it on your own risk. Hope this program is helpful for all. Any comment please send me a e-mail to: dino@ppsc.pme.nthu.edu.tw. Thank you! ^_^
'98.05.23. -
Best way is First create a image using image recorder in nero. Then burn the image.
copying
By merc68 in forum DVD RippingReplies: 13Last Post: 7th Nov 2009, 17:26 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 21:03 -
copying to dvds
By kopkid in forum MacReplies: 3Last Post: 17th Feb 2009, 09:49 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
copying????
By bamf321123 in forum DVD RippingReplies: 1Last Post: 23rd Jun 2007, 06:39
