ok, i have a .ts file which by using MediaInfo i get these info:
General
Format : MPEG-TS
Video
Format : AVC
Format version : Version 2
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Audio
Format : MPEG Audio
Format profile : Layer 2
Mode extension : Intensity Stereo
Emphasis : 50/15ms
Channel(s) : 1 channel
Sampling rate : 24.0 KHz
Video delay : -8h 37mn
the thing is i can easily play it with VLC media player (but with no other player), but i cant demux, convert or do anything else with the audio, and all the problem i have is i cant access its audio! i can extract the video, that's cool, but no audio! I've tried all the tools i could, but still nothing. Even by using MPEG2Repair, it doesnt find any audio PID. what should i do? i want to convert this TS file to a more usable file, like simple DVD MPEG2 file.
BTW, i found this file in an ALIDVR folder, if it helps.
help me brains
thnx
Results 1 to 10 of 10
24KHz intensity stereo coding is unusual.
Try to find specialized demux tools.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I saw lots of references to "Intensity Stereo" in Google. Never used it or edited it myself.
Did you record it by yourself and if yes, which channel/bouqet?
*** Now that you have read me, do some other things. *** -
No i didn't. My boss recorded it, and now he wants me to convert it for him. AFAIK its not a common channel, its a channel from middle east or something. I can ask him if it helps.
This makes a fantastic argument for NOT telling ANYONE you work with that you know anything about working with video.
Idiot boss records a f'ed up program and gives it you. Now you're begging strangers for help.
Divx Converter (free to use for about a week or so before you have to purchase) can work with all kinds of crappy input files. You might download it and see if it will encode to Divx (not MKV - be careful with the output settings) for you. If you get a usable Divx file, you could encode that to another format.
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting from RM to AVI problem...
By Citrus in forum Newbie / General discussionsReplies: 3Last Post: 23rd Apr 2008, 17:19 -
problem with converting rmvb
By fustyler in forum ffmpegX general discussionReplies: 4Last Post: 29th Aug 2007, 20:11 -
problem converting
By aussiemac in forum Video ConversionReplies: 28Last Post: 11th Aug 2007, 16:17 -
persistant converting problem
By craigyboy in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 10th Jun 2007, 11:03
