Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 10 of 10
    Sep 2007
    somewhere in videohelp
    hi, i have flv files, want to convert it to mpeg2 with
    Tmpgenc Express , but it won't open, any suggestion ?
    need to add codec or other ? i have ffdshow
    Can you play the flv in wmp? If not try install flv splitter.
    Or else try convert with another converter like winff or xmedia recode.
    Sep 2007
    i tried it vlc and it can play, didn't have wmp
    don't know how to install flv spliiter cause it .ax
  4. Member classfour's Avatar
    The Heartland, United States
    FLV Player - free
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
    Sep 2007
    thanks classfour, but my problem is not can't play, but it can't load in tmpgenc
  6. Member classfour's Avatar
    I don't believe it's a compatible format. I use TDA3, and have to have mpg or avi to load.
    Sep 2007
    i have 68 flv files, and all it can't load in tmpgenc
    and for mpg or avi didn't have problem to load
  8. Member classfour's Avatar
  9. Member classfour's Avatar
    XVID4PSP converted a flv video to DVD compliant mpg2 that TDA3 had no problem opening.
    Sep 2007
    manage to do it with Winff
    don't know why Xvid4psp, when loading flv, it crash
    still want to know how to install flv splitter.
