    Mar 2008
    Hi everyone. I brought an Inspiron 560 that has a hdmi port on the back of it. I would like to buy a cable that I can attach to hdmi port of the pc then attach it to my tv so I can watch videos on my television. The problem is that I do not have a HD tv. I have three ports--composite, s-video, and component. My tv doesn't have a hdmi port. My dvr from comcast has a hdmi port. Is there any cable or converter that I can buy that will work. Any thoughts or ideas will be appreciated. mary
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    If you don't have component output on your player your options are limited. I don't know if there are any hdmi to component adapters. if there are they are probably pricey and I would imagine not as good as either connection.
    Is it a bluray or dvd player? There are countless dvd players that have component output for near high def upconverting. I am sure there are just as many bluray players that have component output as well.
    My suggestion is to get a hold of a player that has component outputs to go to your component input. That is honestly as good as you can get with your setup. I wouldn't trust a hdmi to component converter. There may be some out there and they may work but its always easiest and best to use the actual connections and not trust a converter.
  3. HDMI to analog video adapters are pretty expensive. Pictures at Dell show only VGA and HDMI on that computer. Don't bother with the simple VGA to video converter cables -- those are for specific devices which have s-video or composite video at the VGA connector. Your computer probably doesn't have that. You could try a VGA to s-video scan converter. But a new graphics card with component/s-video/composite out will be cheaper.
