When importing FLV files to Virtualdub using the FLV import plugin, and then saving them as AVI using Direct Stream Copy, I have noticed that the AVI video seems slightly degraded in quality compared to the FLV when I play both in my preferred FLV player program, FLVPlayer4Free. I might be imagining the difference, but I don't think so.
FLVPlayer4Free (which can also play other formats, not just FLV) has a smoothing option and I wondered if that was the reason for the difference, but it doesn't seem to make any difference, whether it's off or on, for either format. The FLV still looks better than the AVI.
I was under the impression that the FLV Input Plugin lets you open a FLV file and save it as AVI with no loss in quality. Is that correct or not?
Or does FLVPlayer4Free simply have a codec that makes FLVs look better than AVIs?
Or is FLV simply a better looking format than AVI?
I didn't notice the difference when I played both files in other programs but I'm not sure I scrutinized the outputs as carefully.
If you use direct stream copy no conversion is done.
Ask gumbygum:
Why not just keep the original flv?
I mean, is there some reason that you want or need to convert to avi?? -
I don't think that you can use the same codec in an AVI file, so there is a conversion and thus a quality loss.
(EDIT: from following post appears I was wrong about this.)
I think you can losslessly repackage it as mp4 though.
VirtualDub is good for AVI files, but other formats are a bit if hack.
Avidemux might be better.Last edited by AlanHK; 1st Aug 2010 at 11:40.
I just remuxed an FLV with VP6 encoded video to AVI with VirtualDub. It worked fine. You do need to have a VFW decoder installed so VirtualDub can display the video.
Because I'm having so much difficulty finding a program that can edit FLVs easily and losslessly without creating audio sync and other problems. I thought maybe it would be easier to edit them if they were AVIs.
I've monkeyed around with both Virtualdub and Avidemux as well as other programs and all the programs I've tried suck at editing FLVs.
But I don't wanna lose any quality so I want to convert and edit losslessly. -
Yep....editing FLV files does suck. I've tried the FLV plugin for Virtualdub at least twice with no luck. I think I recall using Super to convert FLV files to something else once or twice. I just don't edit FLV files anymore....not worth the hassle.
High Quality Capturing with Little Frame Loss in VirtualDub
By monsoon01 in forum User guidesReplies: 65Last Post: 18th May 2013, 22:33 -
Convert WMV2 video to h264 to save space, but without a quality loss?
By mkvbob in forum Video ConversionReplies: 11Last Post: 12th Apr 2012, 19:28 -
Home video to flv - quality loss and file size
By Bain80 in forum Video ConversionReplies: 3Last Post: 20th Aug 2011, 19:08 -
encoding .VOB to .FLV with least loss in quality
By altavistasf in forum Video ConversionReplies: 9Last Post: 15th Oct 2010, 17:33 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 11:51
