I've been searching all over the internet and tried different options, but still running into problems. I've come to the point to where I need to describe my specific situation in hopes someone can help me with what I need.
I have DVD files that were made by someone else, put in a VIDEO_TS folder. They are in PAL format, and have such files as a menu and a number of IFO and BUP files. I would like to convert all of the files to NTSC. The converter program I have is Movavi.
This is what I've done so far. If I've done anything wrong, please correct me: I am using Movavi, converting the video to NTSC, having it break into 1GB per video in size. After it's done, I will use Format Factory to change all to VOB.
Here are my issues:
1. Would I turn the whole video - using Movavi - into an NTSC file, then rewrite all of the IFO and BUP files?
2. Another problem I ran into is the menu...the video did upload and change in Movavi, but the menu did not. How would I go about changing the menu to NTSC, and how would I make sure the menu and the video are still compatible?
3. The video is broken into three parts...how do I make sure these three different parts don't end up blending into one big video, or cut in between each part?
I'm being more picky because this is for someone else, and I want to make sure it turns out right.
If I think of anything else I will mention it.
Thanks in advance!
Most DVD units nowadays will play PAL and/or NTSC as long as theres no region coding. Just backup your disc and burn to DVD?R - you'll be fine.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
HELP: PAL to NTSC conversion
By hydrophonicaudio in forum ffmpegX general discussionReplies: 5Last Post: 15th Jul 2007, 10:24
