I have a mkv movie that has a default language other than english. I want to get rid of the other languages other than english. Do I have to encode the video again or is there a fast way to make these updates? Thanks for any help.
	I'd use HDConvertToX. You should first analyze the file with MediaInfo and post the results. Anyway, here's what I do for an MKV with X264 video:
 1) Add file in HDConvertToX. Analyze file.
 2) Crop & Resize tab: No Resize & Crop.
 3) Video tab: Encode Using: X264 in MKV. Encoding Mode: Copy Video.
 4) Audio tab: Encode Using: Copy Audio.
 5) Audio & Subs Selection: Uncheck all audio except the stream you want to keep. Same for subtitles.
 6) Specify where to save the new file and give it a title.
 7) Generate Encode.
 Despite the terminology used above, this won't re-encode anything, but will remux a new file with only those streams you want. There are other ways to do it, but that's what I do. Good luck.  Last edited by fritzi93; 31st Jul 2010 at 21:23. Pull! Bang! Darn!
	Easier way is to install MKVtoolnix and add the mkv to mkvmerge GUI and uncheck the unwanted language and save under a new name,no encoding needed. I think,therefore i am a hamster.
  MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-rayBy Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19
  mkv properties in windows explorer (xp)By Mokuton in forum Newbie / General discussionsReplies: 2Last Post: 24th Jul 2011, 13:24
  Video Editing Software: mkv, h264 & DTS Editing?By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 02:29
  VobSub and editing font propertiesBy elmuz in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2010, 05:30
  Editing MKV ?By txl in forum EditingReplies: 5Last Post: 30th Jul 2009, 11:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
