Recently, I converted 6 avi files from three different tv series to DVD mpeg2enc, all with subtitles encoded. All six of the avi files play perfectly synced when I watch them using VLC or QT.
Two of the files (from the same tv series) converted perfectly with subs and audio in sync. The other four (two each from two different series) converted successfully, but with an audio lag that grows increasingly longer as the file plays.All of the avi files are in the HAN container, which has a framerate of NTSC FILM, so I adjust the framerate to NTSC (29.97). When I check the Mplayer Preview before encoding, the audio is in sync. All of the avi files are from series that have been successfully converted in the past few weeks. Here is the information from one of the files with the audio lag (included only parts with info and skipped the repeating parts):
INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler
movtoy4m
Copyright 2002-2006 Johan Lindström
All rights reserved..
INFO: [mpeg2enc] SETTING EXTENDED MMX for MOTION!
INFO: [mpeg2enc] SETTING SSE and MMX for TRANSFORM!
INFO: [mpeg2enc] SETTING EXTENDED MMX for PREDICTION!
INFO: [yuvscaler] input: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] input: chroma: 4:2:0 JPEG/MPEG-1 (interstitial)
INFO: [yuvscaler] input: frame rate: 30000/1001 fps (~29.970030)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x480, 720x480 being displayed
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] frame rate: 29.970 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] output: chroma: 4:2:0 JPEG/MPEG-1 (interstitial)
INFO: [yuvscaler] output: frame rate: 30000/1001 fps (~29.970030)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: 1:1
INFO: [mpeg2enc] Selecting DVD with dummy navigation packets output profile
INFO: [mpeg2enc] Assuming norm NTSC
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/kathy/Desktop/Baker.E13.avi.ff.m2v
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO)
INFO: [mpeg2enc] Bitrate: 4000 KBit/s
INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 0 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] DualPrime: no
INFO: [mpeg2enc] Using one-pass rate control
INFO: [mpeg2enc] GOP SIZE RANGE 7 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] SETTING MMX and MMX for QUANTIZER!
INFO: [mpeg2enc] PAR = 1
INFO: [mpeg2enc] Creating worker thread 0
INFO: [mpeg2enc] NEW GOP INIT length 15
INFO: [mpeg2enc] Worker: getting
INFO: [mpeg2enc] Working: stripe 0/1 1
INFO: [mpeg2enc] Worker: stripe 0 done
INFO: [mpeg2enc] Enc1 0 0( 0) I q=8.36 [100% Intra]
INFO: [mpeg2enc] Enc1 1 1( 1) P q=4.97 [0% Intra]
movtoy4m
INFO: Found EOF in .sub file.
WARN: Read 0, expected 4
INFO: 661 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.13
Statistics:
- Processed 661 subtitles.
- The longest display line had 47 characters.
- The maximum number of displayed lines was 2.
- The normal display height of the font Arial.ttf was 32.
- The bottom display height of the font Arial.ttf was 38.
- The biggest subtitle box had 4254 bytes.
DVDAuthor::dvdauthor, version 0.6.11.
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing /Users/kathy/Desktop/Baker.E13.avi.ff.mpg...
STAT: VOBU 16 at 3MB, 1 PGCS
STAT: VOBU 32 at 6MB, 1 PGCS
STAT: VOBU 48 at 11MB, 1 PGCS
INFO: Video pts = 0.133 .. 3913.976
INFO: Audio[8] pts = 0.133 .. 3913.093
INFO: Audio[32] pts = 0.363 .. 3912.753
STAT: VOBU 7965 at 1968MB, 1 PGCS
INFO: Generating VTS with the following video attributes:
INFO: MPEG version: mpeg2
INFO: TV standard: ntsc
INFO: Aspect ratio: 4:3
INFO: Resolution: 720x480
INFO: Audio ch 0 format: mp2/2ch, 48khz 20bps
STAT: fixing VOBU at 3MB (17/7965, 0%)
STAT: fixing VOBU at 6MB (33/7965, 0%)
STAT: fixing VOBU at 11MB (49/7965, 0%)
STAT: fixing VOBU at 15MB (65/7965, 0%)
STAT: fixing VOBU at 19MB (81/7965, 1%)
STAT: fixed 7965 VOBUS
INFO: dvdauthor creating table of contents
INFO: Scanning /Users/kathy/Desktop/Baker.E13.avi.ff.mpg.DVD/VIDEO_TS/VTS_01_0.IFO
Sat Jul 31 12:05:05 HST 2010
I suspect it's the last section, huh?
Thank you for any suggestions to help fix this!
The issue is probably the sped-up video, but it's easier to shorten the audio to make it match, if the solution can't be found in the encoding.
I know it's hard to measure, but could the audio lag be around 25%, i.e. 16 seconds of video need 20 seconds of audio to get to the same point? That would be explainable with a NTSC FILM/NTSC mixup.
I have no idea what that is.Originally Posted by macgurl
Why would you adjust a framerate that is perfectly fine for DVD? Changing the framerate is one possible cause for sync issues.Originally Posted by macgurl
MPlayer is playing the source file; any encoding issue wouldn't show at this time.Originally Posted by macgurl
You also cut out the audio encoding part, although I don't expect anything weird there.Originally Posted by macgurl
Never thought of it that way; will try and measure. It's kind of funny that it's been working fine for a while now and all of a sudden this problem crops up, but only for certain series.
If I don't change the framerate, the resulting video is only a portion of the video -- a 60 min. video is only 25 minutes long. Changing the framerate was the only way to get the entire video to encode properly.
Ah, I see. Thanks, I learned something new!
I just did two more episodes with no problem, but still can't get those 4 that didn't work earlier to work.
The way I see it, those four files have something ‘special’ about them, that may not be apparent with some players, but crops up at conversion time.
One other suggestion: mpeg2enc allows for one of three decoders to use: QuickTime, mplayer or ffmpeg. You can select that in the Options tab. The default QuickTime decoder is pretty good, but can get confused by some files occasionally. If a conversion error occurs which might be caused by a decoder, then it's worth to try another decoder. (Unchecking both QuickTime and mplayer sets ffmpeg as the decoder.)
So do try these two alternatives to see if the conversion goes better that way for these files.
I'm trying your suggestion now--deselected "decode with quicktime" under options and running mpeg2enc again.
Earlier, a new episode became available and I tried mpeg2enc changing the framerate to NTSC (29.97) like I usually do, and the same problem of lagging audio occurred.
Then I tried mpeg2enc again leaving the framerate at NTSC FILM. The result was the whole episode (65 minutes long) was shortened to 30 minutes, with less audio lag.
I've kept the process information for both, but will run mpeg2enc after adjusting the option, and will see how that goes before I post the process info.
Thank you for your suggestions. Will post update as soon as it is complete.
The file that I tried to encode with "decode with quicktime" deselected failed to finish. It stopped at about 30 minutes (out of 65 minutes).
Of the different variations, the closest seems to be the original--and I guess I'll just live with them being a second or two off on the audio. Another mystery of life!
FYI--the process info:
Sat Aug 7 16:36:07 HST 2010
movtoy4m
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/kat/Documents/A Downloads/Baker.E15.avi.ff.m2v
INFO: [mpeg2enc] Enc1 0 0( 0) I q=9.36 [100% Intra]
INFO: [mpeg2enc] Enc1 1 1( 1) P q=5.35 [0% Intra]
INFO: [mpeg2enc] Enc1 117514 117514(12) P q=3.00 [1% Intra]
INFO: [mpeg2enc] Enc1 117515 117515(13) P q=3.00 [2% Intra]
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 117518!
INFO: [mpeg2enc] Enc1 117516 117516(14) P q=3.00 [1% Intra]
INFO: [mpeg2enc] Signaling last frame = 117517
INFO: [mpeg2enc] Enc1 117517 117517( 0) I q=3.00 [100% Intra]
INFO: [mpeg2enc] Sequence end inserted
INFO: [mpeg2enc] Guesstimated final muxed size = 1921181749
INFO: [mpeg2enc] SHUTDOWN worker
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
configuration: --enable-memalign-hack --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-amr_wb --enable-pthreads --enable-x264
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
built on Apr 15 2006 04:58:19, gcc: 4.0.1 (Apple Computer, Inc. build 5250)
Input #0, avi, from '/Users/kathy/Documents/Azureus Downloads/Baker.E15.avi':
Duration: 01:05:21.1, start: 0.000000, bitrate: 1499 kb/s
Stream #0.0, 29.98 fps(r): Video: mpeg4, yuv420p, 624x352
Stream #0.1: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Output #0, mp2, to '/Users/kat/Documents/A Downloads/Baker.E15.avi.ff.mp2':
Stream #0.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
Stream mapping:
Stream #0.1 -> #0.0 [sync #0.0]
Press [q] to stop encoding
size= 1538kB time=56.3 bitrate= 224.0kbits/s
size= 2895kB time=105.9 bitrate= 224.0kbits/s
size= 4242kB time=155.1 bitrate= 224.0kbits/s
size= 5364kB time=196.2 bitrate= 224.0kbits/s
size= 6826kB time=249.6 bitrate= 224.0kbits/s
size= 8481kB time=310.2 bitrate= 224.0kbits/s
size= 10079kB time=368.6 bitrate= 224.0kbits/s
size= 11767kB time=430.3 bitrate= 224.0kbits/s
size= 13041kB time=476.9 bitrate= 224.0kbits/s
size= 14747kB time=539.3 bitrate= 224.0kbits/s
size= 16522kB time=604.2 bitrate= 224.0kbits/s
size= 18237kB time=666.9 bitrate= 224.0kbits/s
size= 20024kB time=732.3 bitrate= 224.0kbits/s
size= 21778kB time=796.5 bitrate= 224.0kbits/s
size= 23570kB time=862.0 bitrate= 224.0kbits/s
size= 25374kB time=928.0 bitrate= 224.0kbits/s
size= 27133kB time=992.3 bitrate= 224.0kbits/s
size= 28941kB time=1058.4 bitrate= 224.0kbits/s
size= 30679kB time=1122.0 bitrate= 224.0kbits/s
size= 32486kB time=1188.0 bitrate= 224.0kbits/s
size= 34118kB time=1247.8 bitrate= 224.0kbits/s
size= 35928kB time=1314.0 bitrate= 224.0kbits/s
size= 37729kB time=1379.8 bitrate= 224.0kbits/s
size= 39357kB time=1439.4 bitrate= 224.0kbits/s
size= 41165kB time=1505.5 bitrate= 224.0kbits/s
size= 42740kB time=1563.1 bitrate= 224.0kbits/s
size= 44544kB time=1629.0 bitrate= 224.0kbits/s
size= 46321kB time=1694.0 bitrate= 224.0kbits/s
size= 48006kB time=1755.6 bitrate= 224.0kbits/s
size= 49821kB time=1822.0 bitrate= 224.0kbits/s
size= 51563kB time=1885.7 bitrate= 224.0kbits/s
size= 53354kB time=1951.2 bitrate= 224.0kbits/s
size= 55107kB time=2015.3 bitrate= 224.0kbits/s
size= 56914kB time=2081.4 bitrate= 224.0kbits/s
size= 58669kB time=2145.6 bitrate= 224.0kbits/s
size= 60475kB time=2211.6 bitrate= 224.0kbits/s
size= 62276kB time=2277.5 bitrate= 224.0kbits/s
size= 64053kB time=2342.5 bitrate= 224.0kbits/s
size= 65867kB time=2408.9 bitrate= 224.0kbits/s
size= 67547kB time=2470.3 bitrate= 224.0kbits/s
size= 69353kB time=2536.3 bitrate= 224.0kbits/s
size= 70985kB time=2596.0 bitrate= 224.0kbits/s
size= 72774kB time=2661.5 bitrate= 224.0kbits/s
size= 74585kB time=2727.7 bitrate= 224.0kbits/s
size= 76065kB time=2781.8 bitrate= 224.0kbits/s
size= 77881kB time=2848.2 bitrate= 224.0kbits/s
size= 79503kB time=2907.6 bitrate= 224.0kbits/s
size= 81312kB time=2973.7 bitrate= 224.0kbits/s
size= 83126kB time=3040.0 bitrate= 224.0kbits/s
size= 84845kB time=3102.9 bitrate= 224.0kbits/s
size= 86664kB time=3169.4 bitrate= 224.0kbits/s
size= 88410kB time=3233.3 bitrate= 224.0kbits/s
size= 90219kB time=3299.4 bitrate= 224.0kbits/s
size= 91983kB time=3364.0 bitrate= 224.0kbits/s
size= 93799kB time=3430.4 bitrate= 224.0kbits/s
size= 95503kB time=3492.7 bitrate= 224.0kbits/s
size= 97291kB time=3558.1 bitrate= 224.0kbits/s
size= 99099kB time=3624.2 bitrate= 224.0kbits/s
size= 100810kB time=3686.8 bitrate= 224.0kbits/s
size= 102611kB time=3752.6 bitrate= 224.0kbits/s
size= 104128kB time=3808.1 bitrate= 224.0kbits/s
size= 105932kB time=3874.1 bitrate= 224.0kbits/s
size= 107202kB time=3920.5 bitrate= 224.0kbits/s
video:0kB audio:107202kB global headers:0kB muxing overhead 0.000000%
INFO: [mplex] mplex version 1.9.0 (2.2.7 $Date: 2006/02/01 22:23:01 $)
INFO: [mplex] File /Users/kat/Documents/A Downloads/Baker.E15.avi.ff.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Users/kat/Documents/A Downloads/Baker.E15.avi.ff.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/kat/Documents/A Downloads/Baker.E15.avi.ff.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 4000000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/kat/Documents/A Downloads/Baker.E15.avi.ff.mp2)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 1 original
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 4317296
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in delay = 9009 Video delay = 9009 Audio delay = 12012
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 0 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 0 frame=000000 sector=00000000
INFO: [mplex] STREAM c0 completed @ frame 163355.
INFO: [mplex] Scanned to end AU 117517
INFO: [mplex] STREAM e0 completed @ frame 117517.
INFO: [mplex] Multiplex completion at SCR=352869668.
INFO: [mplex] Video e0: buf= 225648 frame=117517 sector=00952736
INFO: [mplex] Audio c0: buf= 0 frame=163355 sector=00054345
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 1921181749 bytes
INFO: [mplex] Sequence headers: 7905
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 117518
INFO: [mplex] No. Groups : 7905
INFO: [mplex] No. I Frames : 7905 avg. size 49769 bytes
INFO: [mplex] No. P Frames : 109613 avg. size 13937 bytes
INFO: [mplex] No. B Frames : 0 avg. size 0 bytes
INFO: [mplex] Average bit-rate : 3919200 bits/sec
INFO: [mplex] Peak bit-rate : 5136000 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 156054
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 109775232 bytes.
INFO: [mplex] Syncwords : 163356
INFO: [mplex] Frames : 163356 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 683
INFO: [mplex] MUX STATUS: no under-runs detected.
INFO: Locale=C
INFO: Converting filenames to US-ASCII
INFO: Detected subtitle file format: subviewer
INFO: Opened iconv descriptor. *UTF-8* *ISO-8859-1*
INFO: Read 639 subtitles
INFO: Adjusted 2 subtitle(s).
INFO: Unicode font: 242 glyphs.
STAT: 0:00:00.000
STAT: 0:00:02.233
STAT: 0:00:08.493
STAT: 0:00:13.633
STAT: 0:00:37.613
STAT: 0:00:51.313
STAT: 1:05:10.783
STAT: 1:05:16.663
INFO: 639 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.13
Statistics:
- Processed 639 subtitles.
- The longest display line had 44 characters.
- The maximum number of displayed lines was 3.
- The biggest subtitle box had 4048 bytes.
STAT: Processing /Users/kat/Documents/A Downloads/Baker.E15.avi.ff.mpg...
STAT: VOBU 32 at 7MB, 1 PGCS
STAT: VOBU 64 at 15MB, 1 PGCS
STAT: VOBU 80 at 19MB, 1 PGCS
STAT: VOBU 96 at 23MB, 1 PGCS
STAT: VOBU 112 at 27MB, 1 PGCS
STAT: VOBU 128 at 31MB, 1 PGCS
STAT: VOBU 144 at 35MB, 1 PGCS
STAT: VOBU 160 at 39MB, 1 PGCS
STAT: VOBU 176 at 43MB, 1 PGCS
STAT: VOBU 192 at 47MB, 1 PGCS
STAT: VOBU 208 at 51MB, 1 PGCS
STAT: VOBU 224 at 55MB, 1 PGCS
STAT: VOBU 7888 at 1979MB, 1 PGCS
STAT: VOBU 7904 at 1983MB, 1 PGCS
INFO: Video pts = 0.133 .. 3921.317
INFO: Audio[8] pts = 0.133 .. 3920.677
INFO: Audio[32] pts = 0.133 .. 3919.166
STAT: VOBU 7905 at 1984MB, 1 PGCS
STAT: fixing VOBU at 3MB (17/7905, 0%)
STAT: fixing VOBU at 7MB (33/7905, 0%)
STAT: fixing VOBU at 11MB (49/7905, 0%)
STAT: fixing VOBU at 15MB (65/7905, 0%)
STAT: fixing VOBU at 19MB (81/7905, 1%)
STAT: fixing VOBU at 23MB (97/7905, 1%)
STAT: fixing VOBU at 27MB (113/7905, 1%)
STAT: fixing VOBU at 31MB (129/7905, 1%)
STAT: fixing VOBU at 35MB (145/7905, 1%)
STAT: fixing VOBU at 39MB (161/7905, 2%)
STAT: fixing VOBU at 43MB (177/7905, 2%)
STAT: fixing VOBU at 47MB (193/7905, 2%)
STAT: fixing VOBU at 51MB (209/7905, 2%)
STAT: fixing VOBU at 55MB (225/7905, 2%)
STAT: fixing VOBU at 1983MB (7905/7905, 99%)
STAT: fixed 7905 VOBUS
INFO: Scanning /Users/kat/Documents/A Downloads/Baker.E15.avi.ff.mpg.DVD/VIDEO_TS/VTS_01_0.IFO
Sat Aug 7 17:18:46 HST 2010
audio lag in .mov to .flv converted files
By french-petzouille in forum ffmpegX general discussionReplies: 5Last Post: 3rd Mar 2012, 12:05 -
tsMuxeR and Audio Lag
By imrealdumb in forum Video ConversionReplies: 3Last Post: 14th Jun 2011, 18:28 -
Which Free Media Player can play this without audio lag?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 5th Feb 2011, 00:58 -
Audio/Video Out of Sync/Lag When Editing Clips
By DrawnIntoIt88 in forum EditingReplies: 2Last Post: 15th Dec 2007, 08:03 -
After using ConvertX, major audio lag
By bear2616 in forum AudioReplies: 4Last Post: 17th Oct 2007, 13:42
