I exported a project to MPG from my video editor (Magix Movie Edit Pro 16 Plus) using HD settings (1920 x 1080). It plays OK in most of my usual players but in VideoRedo it doesn't. It 'stutters' and jerks. Sometimes it display an entirely green screen at the start and won't play ay all. Similar behaviour in both PowerDVD. Does this ring any bells with anyone please?
In case it helps, MediaInfo includes the following:
Format: MPEG Video
Format version: Version 2
Format profile: High@High
Format settings, BVOP: Yes
Format settings, Matrix: Default
Format settings, GOP: M=3, N=15
Duration: 5mn 9s
Bit rate mode: Variable
Bit rate: 67.7 Mbps
Nominal bit rate: 100.0 Mbps
Width: 1920 pixels
Height: 1080 pixels
Display aspect ratio: 16:9
Frame rate: 25.000 fps
Color space: YUV
Chroma subsampling: 4:2:0
Bit depth: 8 bits
Scan type: Interlaced
Scan order: Top Field First
Bits/(Pixel*Frame): 1.306
Stream size: 2.44 GiB (97%)
Terry, East Grinstead, UK
Bells yes.
To edit video with a resolution at 1920 x 1080 can be done but what your asking of your current systems setup is too much ... it's simply not fast enough.
Time to upgrade. -
Thanks both.
I noted that 'old' players like Media Player Classic (MPC) played these high res MPGs fine. So I assumed VideoRedo would do so too. But if that (and PowerDVD) are designed exclusively for SD not HD then it is indeed sort of obvious!
So do more recent versions of VideoRedo and PowerDVD handle HD DVD? Is that what you mean by 'time to upgrade'?
16:9 divx movie won't play properly on my TV
By romino in forum Video ConversionReplies: 4Last Post: 22nd Oct 2010, 07:36 -
VideoReDo won't let me go any further...
By dadrab in forum Capturing and VCRReplies: 10Last Post: 23rd Jan 2009, 18:12 -
HDTV2DVD outputs won't play back properly
By papatop in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 10th Dec 2008, 20:45 -
mpg files won't play in IE
By Krispy Kritter in forum Software PlayingReplies: 3Last Post: 31st Oct 2008, 14:42 -
Files that won't play properly in WMP or after conversion
By Trapper Dave in forum Video ConversionReplies: 1Last Post: 3rd Jun 2007, 14:26
