Hello
i want ask about best way and converter and settings to convert my MTS video files to best youtube full hd quality
my MTS file is full HD 1920x1080
so please help me and give me good converter from MTS to mp4 (with best settings for youtube full hd 1080) With video and sound settings
i know i can upload my MTS file directly to youtube and youtube convert it to mp4 or flv but this way take long time on youtube and MTS file not working fine on some PC's so i want convert all my video to mp4 before upload it..
this video uploaded by me for test only i upload MTS file directly to youtube without any editing or convert
http://www.youtube.com/watch?v=cdocL1aVD2Y
	hi
	i try this before but i don't know what the best mp4 setting for full hd on youtube hi
	encode with x264 and use aac audio. y.t limits of 15 minutes and 2 GB. make the video bitrate anything you want over 5mbps to get the HD limks. more is better but the filesize also goes up. make sure to upload progressive video not interlaced. if needed select the video filter - deinterlace - slower. --
	ok thanx but what about video size? make it 1920x1080 or what?
 i put bitrate 8048 kbps good? or leave it on constant quality ?
 framerate : same as source?hi
	i try this program and the video result not clear there is small lines appear when video working and the format is m4p not mp4
 did u have another software better thishi
	mediacoder is another good encoding program. the lines are from interlaced video, make sure to check that deinterlaicng is on. --
	1920x1080p is ok, but you'll probably get just as good of a youtube video at 1280x720p. 8000kbps is fine. --
  How to merge multiple .mts files (canon HF) into one single .mts fileBy frmsuv2van in forum Video ConversionReplies: 15Last Post: 5th Sep 2014, 22:21
  To add youtube full screen button in forumBy roma_turok in forum FeedbackReplies: 4Last Post: 11th Oct 2010, 09:56
  Do you see any diff betw default in HD and full HD on YouTube?By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 10th Feb 2010, 14:44
  Rendering .MTS files from my Canon HF-S100 in Vegas Pro 8.0 for youtube.By fullerfour in forum Newbie / General discussionsReplies: 6Last Post: 24th Dec 2009, 01:05
  Check out how YouTube handles my MTS uploadsBy Priapism in forum Video Streaming DownloadingReplies: 6Last Post: 25th Aug 2009, 13:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
