Hey guys,
I'll say that I did this successfully with MKVTools, converting a Blu-ray rip from MKV/FAAC to AVI (either mp3 or aac, i can't remember). Of course I ended up with the demuxed files (is that the word?) and would like to either remux those or simply convert to another container that can be played on the LG. Let me first say, it was not the video format that the LG couldn't play, it was the FAAC audio format.
My goal is to convert the audio only, leaving the video at the best quality, into a playable format for the TV via a USB connected hard drive. I've got QT Pro, MKVTools, VLC and Handbrake. I've only had success with MKVTools, but I'd like to have a more elegant solution of ending up with a single container instead of separate files.
What's the best way to do what I'm asking? I'm also looking for easiest. If MKVTools is it, then so be it, but just want to make sure I'm not missing something. Thanks!
Jonathan
Hi Jony,
maybe i've had too many beers tonite but you sound like you know what your doing. Do you work for LG and afraid to contact the factory?? You sound like a jedi. Anyway, get to know ffmpeg it will be your best friend (if you don't already). http://ffmpeg.org/general.html
I'd give you examples and cli but honestly, read the help link first and you still have questions come back. Cheers
Best quality option to convert 1080p mkv to 720p mkv
By carlmart in forum Video ConversionReplies: 5Last Post: 14th Mar 2010, 07:17 -
25fps 1080i mkv convert to 24fps 1080p or 720p mkv?
By brent1a in forum Video ConversionReplies: 6Last Post: 9th Feb 2010, 09:57 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 01:17 -
What Windows resolution for viewing 720/1080 MKV's?
By leopardx in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2009, 19:43 -
Best Aspect Ratio playing .mkv video via VLC/Quicktime for viewing on HDTV
By iMacMan in forum MacReplies: 4Last Post: 19th Feb 2008, 01:04
