Hi. I have a friend who recommended the "AVS Video Converter", but the thing is it costs money.
The video output is quite good, and I was wondering if it used some proprietary codecs to achieve this?
Are there free alternatives that can create video that looks that good? I also think he liked the way everything was automated, one click conversion (using defaults), burning to the DVD for you (no burning proggy needed), etc...
Has anyone ever reviewed this software? Because at first glance, I thought the official site looked of questionable nature, ie - junk.
Return here: https://www.videohelp.com/tools/AVS_Video_Converter and scroll down to the part where it says "Similar tools/Alternative to AVS Video Converter."
I have avs video converter and it is good for oddball formats.
However I am now using format factory a lot more frequently. It handles a ton of inputs and can output to just about anything and is free.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
depending on the input format you can choose from a lot of different free tools. the one i'd start with first is avstodvd. then there's the film machine, there's a old free version of convertxtodvd, and others in the tools section. as for burning dvds i wouldn't use anything but the free imgburn, even if a program has the capability built in.
AVS Video Converter - No audio
By Djard in forum Video ConversionReplies: 1Last Post: 21st Jul 2011, 15:49 -
AVS video converter
By jakewoodblues in forum Video ConversionReplies: 1Last Post: 20th Oct 2009, 15:41 -
AVS Video Converter vs ConvertxtoDVD
By kuerenz in forum Video ConversionReplies: 5Last Post: 10th Oct 2009, 10:44 -
avs video converter 6 help
By Hpy68 in forum Video ConversionReplies: 3Last Post: 5th Oct 2008, 20:53 -
avs video converter
By ocko in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2008, 17:33
