  1. Hi all,
    I'm using Vegas Pro 9.0e 64 bits. I'd like to create an HD video : 1280 x 720.
    I need to import some videos for editing in Vegas. I have a bunch of old videos that are encoded with the Intel Video Indeo 5.0 codec. They can't be read into Vegas as there is no 64 decompressor for this codec.
    So I used Virtual Dub and the Ffdshow encoder to convert these videos to AVC. After this conversion, MediaInfo says :
    Format : AVI
    File size : 10.0 MiB
    Overall bit rate : 45.8 Mbps
    Writing library : VirtualDub build 32706/release
    Video ID : 0
    Format : AVC
    Format profile : High 4:4:4 Predictive@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Codec ID : H264
    Duration : 1s 840ms
    Bit rate : 45.7 Mbps
    Width : 768 pixels
    Height : 576 pixels
    Display aspect ratio : 4:3
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 4.135
    Stream size : 10.0 MiB (100%)
    Writing library : x264 core 1679488396May 25 2009
    Encoding settings : cabac=1 / ref=1 / deblock=0:0:0 / analyse=0x3:0x113 / me=hex / subme=5 / psy_rd=0.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=1 / nr=0 / decimate=1 / mbaff=0 / bframes=0 / keyint=200 / keyint_min=1 / scenecut=40 / rc=cqp / qp=0
    While editing in Vegas : I have problems with these videos . Sometimes, some of them are shown red and "offline". After the rendering, some clips are rendered completely black. Sometimes a frame is rendered too dark, and the next frame will be too light. In a word, it's a mess. I'd like to know if other people manage to work with AVC encoded videos in Vegas?
    Anyway, i'm pretty sure I need to convert my original videos to another format. I could use an uncompressed AVI or a Targa sequence, but it would take too much disk space. Also the original videos are compressed, so why not keep them that way?
    So I'd like to know your suggestions for a compressed video format that works inside Vegas 64 bits.
    Gz
  2. Any Vegas user willing to share the love?
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If they are standard D1 resolution (which they appear to be) I would use cedocida to output standard DV. Simplest to edit, and Vegas will have no problems working with it.
    Read my blog here.
    Oct 2005
    666th portal
    you could also try huffyuv or lagarith lossless codecs, but avc 4:4:4 is not a good choice.
  6. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by grendizer View Post
    Hi all,
    Width : 768 pixels
    Height : 576 pixels
    That isn't HD video. It is a square pixel representation of 576 line progressive 25 fps SD video with 4:3 aspect ratio. It is encoded to AVC H.264 which will be difficult for Vegas.
    I'd go back to Virtualdub and output to DV format (Cedocida DV codec) to 720x576i which is slightly horizontally compressed. This produces a DV standard definition result which Vegas can edit natively. Or, you could export square pixel progressive to huffyuv and create a custom 768x576 project template in Vegas.
    If you intend to upscale this to 1280x720p (960x720 square pixel with side pillar bars) better to do it in AVIsynth before import to Vegas. Use huffyuv as the transfer format then set a 1280x720p Vegas project.
    http://www.kiva.org/about
  7. Thanks a lot for your answers, they are very educational.
