I've posted this in the newbie conversion forum, and have also done a search for it, with no luck.
When I edit an AVI in Premiere 6.1 and export to a new AVI file with the DivX 5 codec, the new file has good audio. But if I also create a .divx file, that file seems to have no audio.
Since P6 can't import a .divx file (and the Divx player 2.0 dosn't play any sound), how can I check wether any audio actually exists in the file?
Any DivX experts?
Results 1 to 9 of 9
Switch on "Write convertion log" it will tell you what it's done. Your .divx has no audio if the original audio is not supported.
AVI audio format 0001 is not supported -
Well the logs don't seem to mention anything about audio. But they do all have this in common:
they all say [built with mp4file library: Version 0.20, 26 Feb 2002]
aviin_open() : aviin_readheaders() failed
B-frame detection failed -
Hi
I think you need to compress the audio to mp3.
check this out
http://www.divx.com/support/guides/virtual_dub_guide.php?cid=2&gid=2 -
Well, again, thats for compressing to a DivX AVI file. I'm interested in creating a file ending in the .divx extension.
When I do that, the new file has no sound.
Thanks for replying though. -
Well i've tried that too.
It's weird that there seems to be no setting for audio. I'm talking about the first page of the DivX settings window. At the bottom of the window, it has a check box to "create a divx file".
Is there any player that can show me if there is indeed audio in the file? At least I could see if it's an encoding problem or a playback problem. -
A far as I know only the Divx player that is provided with it.
I have it as I have seen a few Divx5 movies, But I don't use it to encode. 4.8 will do me, when I want it. I don't think your divx file has any audio, have you tried it will a standard capture ?. Ill give it a try... -
One step foward and three steps back...
DIVX PLAYER 2 caused an invalid page fault in
module DIVX PLAYER 2.0 ALPHA.EXE at 017f:005b8e17.
Registers:
DivX 5, dont support the old DivXaudio codecs, I have read to install 3.11 alpha again, also Nimo
http://www.divx-digest.com/software/nimo_pack.html
Converting Divx to AVI with a Twist
By Deathbot70 in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2012, 12:42 -
Help/Advice Converting .AVI Divx Files To ...
By MourningStar in forum Video ConversionReplies: 2Last Post: 12th Dec 2009, 16:18 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35 -
best software for converting dvd to avi, divx etc ???
By geronemo in forum Newbie / General discussionsReplies: 4Last Post: 15th Nov 2007, 12:48 -
Converting ISO to AVI (Divx or Xvid)
By cyberjackal in forum Video ConversionReplies: 2Last Post: 11th Jul 2007, 10:50
