  1. Do these adequately work? I don't have a firewire input on my motherboard and I'm considering purchasing this. Any idea what program I should use to transfer the files over? I only have tmpgenc dvd author 3 installed.
    Feb 2007
    For the price of a cable, you should instead purchase a firewire PCI card. They are cheap, they often have around 3 firwire ports on the back and connectors for internal use as well.
  3. If you're refering to the cable I think you are, it converts to the incoming DV on the Firewire side to MPEG1 on the USB side. Pretty useless.
    John Miller
  4. Ugh, what a pain. Thanks for the info.
