Results 1 to 10 of 10
    Mar 2009
    Hello.. I'm looking to add a 2nd HD wireless media player. I currently have a Xbox running XBMC and I just love the GUI on the XBMC !! I will be streaming videos through my home network on a PC running Windows XP. I'm leaning towards getting a WD TV Live Plus along with a wireless card. From what I've read this unit works great but is a little challenged in the GUI department (I know this is trivial to some). I REALLY like how you can use a scraper with the XBMC to auto download movie or tv information and thumbnails ! Does anyone know of a unit that will auto download this information ? Any suggestions / comments are welcome !
    Thank you !
  2. NEttop? with Windows/MC installed? WD is also good. Qnap nmp1000 is also quite stylish, and should be on sale soon.
    The electronic components of the power part adopted a lot of Rubycons.
    I highly suggest the Western Digital WD TV Live Network-ready HD Media Player
    Amazon has it for $100 with free shipping: http://www.amazon.com/gp/product/B002KKFP9Y?ie=UTF8&tag=thdifa-20&linkCode=as2&camp=17...SIN=B002KKFP9Y
    I really like my older non-Plus WDTV.
    Mar 2009
    Thanks so much for the replies !
    Have you modified this equipment at all by using any other type of firmware such as WDLXTV – enhanced WDTV firmware ? The main complaint that I hear about this unit is the GUI. I know this is trivial, but I really like the look of XBMC and the fact that it will auto download thumbnails for you ! Would you happen to be running your WD TV wireless or wired ? If wireless, what wireless adapter do you use and how well is it working for you ?
    Thanks for your time !
    The GUI is fine.
    Honestly, you'd have to be a moron to have issues operating the GUI. So disregard whatever you heard/read.
    No, I'm not modifying the unit. Ain't broke, so not fixing it.
  6. Yeah i would have to agree that the wdtv is pretty good. The qnap is unknown quantity and is very expensive ($300) but looks cool.
  7. Personally I prefer a plain text file listing. But if you require an XBMC-like GUI the WDTV is not for you. Brad's firmware does add some movie info sheets though. But I think you need to put the info together yourself. It's not automatically downloaded.
    Found this though: http://wdtvforum.com/main/index.php?topic=1349.0
    The PopBox is supposed to have those sorts of features but it looks like it's not yet "finished". Maybe the BoxeeBox in December (last I heard).
  8. Get a netbook & connect it to your TV.
    Aug 2010
    If you're looking for a XBMC Media Center PC, but don't want to build one yourself, you should check out Modified Konstruct's custom media center PC. It's a an Acer Aspire Revo chassis with a XBMC install. And it's only $300. Here's the link: http://www.modifiedkonstructs.com/our-services/mk-x1
    Feb 2003
