When I ripped my DVDs for playing on my AppleTV I never thought it through very well and only created an AC3 audio stream using Handbrake. Now I've got an iPad I want to watch some of those movies on the iPad but obviously they won't play. I've had a search around and know not enough to figure out how to easily (on a Mac) create a new AAC audio stream in the file (while keeping the AC3 stream) - what's the easiest way? Any ideas? Many thanks in advance for your help!! Much appreciated.
William
Howdy,
I'm not sure if you found a solution yet, but I just uploaded a very early, pre-beta release of MKVtools that should do this for you. The key word is should
. I added a dual audio output option intended for AppleTV users, and though MKVtools is primarily intended for use with mkv files, all of its functionality should also work on mp4 videos or avi videos for that matter. So you should be able to passthrru the original video and audio, and have a new aac audio stream created and muxed into the output. I just haven't done much testing on videos other than mkv's so I'd love to get some feedback.
Hi Wokavan,
I'm glad the beta is working out for you. For now, unfortunately, the 2 Ch. audio is basic stereo. I'd like to output Dolby Pro Logic, but in my limited research I haven't found a good solution using mencoder. So this issue has been shifted down the todo list by other issues with less time intensive solutions. Hopefully it'll be available someday. I might have to look into ffmpeg.
A splitter for .m4v files
By yuvika in forum Newbie / General discussionsReplies: 0Last Post: 6th May 2010, 10:14 -
Convert .m4v (H.264+AAC) to XviD
By mattr in forum MacReplies: 3Last Post: 20th Sep 2008, 11:25 -
Syncing .m4v and AAC files in flash player
By Pureweb in forum Video Streaming DownloadingReplies: 0Last Post: 13th Aug 2008, 11:33 -
mkv -> m4v with AC3 soundtrack problem
By jamesmac in forum ffmpegX general discussionReplies: 2Last Post: 12th Aug 2008, 17:54 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 19:23
