How can I join two MPEG-2 (.MPG) files together? (ie. without any recoding, etc)
Also, how about joining two AVI files together? (is VirtualDub the best method for that using Direct Stream copy?)
For Mpeg-2, AVI Demux is a better choice, as virtualdub doesn't do mpeg-2. Virtualdub is OK for AVI files, assuming they have the same resolution, aspect ratio and framerate, and the audio parameters also match.
Read my blog here.
Thanks! AVI Demux won't recompress the files or anything, right?
Also, is there anything better than VirtualDub for AVI? (is AVI Demux better for AVI as well?) -
For AVI Avidemux and VDub probably give equally good results in just joining.
However, VDub is fussier while Avidemux can cope better with imperfections.
As for MPEG2, MPEG-VCR is excellent but not free -- though they periodically have free offers if you keep your eyes open at e.g. http://www.giveawayoftheday.com -
VideoReDo is a good investment and will do the job,
Boilsoft Videojoiner works well for joining video but is a one trick pony.
MPEG Streamclip to join files but not transcode?
By Corbey in forum Video ConversionReplies: 2Last Post: 12th Apr 2013, 12:18 -
cmd line tool to join two mpeg-2 files
By nighthawk2018 in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2010, 22:13 -
join mpeg files without re encoding
By akakiami in forum Video ConversionReplies: 5Last Post: 12th Nov 2008, 01:18 -
need to join 2 dvd compliant mpeg files (having identival characteristics)
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 20th Oct 2008, 10:37 -
can't join simillar mpeg-1 files without re-encoding
By sohaibrazzaq in forum EditingReplies: 3Last Post: 26th Jan 2008, 08:09
