Hi,
i've ripp BD discs to HDD folder with AnyDvd 6.6.8 trial, now i want to choose only the main movie and eng audio.
I'll use the file for edition in Vegas, i need to keep full HD quality and have a/v in the same file, what tool btw DvdFab ClownBd TsMuxer Eac3MoreGui BdHdStreamExtractor or another one will output best for using in Vegas. File type .m2ts is good or .ts is better in my case, or is it exacly the same.
From Vegas output will be stereo 2.0 or 2.1, what audio do select in streams list, choices are btw DolbDig ; TrueHd ; DtsHd and PCM. Each source doesn't have all the strems, one has only DTSHD. What to choose in order of preference ?
I joined BdInfo files.
Thank you.
Parallel topic.
Results 1 to 11 of 11
I had BSOD, with memtest86+ i detected lots of erros (ram was new i couldn't imagine it was nonfonctional, i resended for exchange).
While ripping i had this memory, can it cause bad ripping ? -
possibly, but more likely program crashes.
Thanks, i'll redo all when received new RAM
For using in Vegas, DtsHd will be correctly handled and outputed in 2.1 ? Is it better to take only the core while ripping (for Vegas compatibility) ?
No answer !?Hi,
I enabled FfdShow for Vc-1 in Wmv9 and libavcodec, i couldn't open the files in Vegas. I can read them even w/o FfdShow in Wmp...
So i had the idea to make verry good Dvd quality encoding of my BluRay's for using in Vegas easyly. What is the best software do do that ? TmpgEncXpress perhaps ?
Or another NLE can open VC-1 natively w/o ffdshow filters ?
EDIT: m2ts sample from internet opens... but mpg2Last edited by Klemc; 2nd Aug 2010 at 12:12.
Is there really no application that can ripp/save this video ?
By harry88 in forum Video Streaming DownloadingReplies: 4Last Post: 5th Mar 2012, 13:05 -
Sony Vegas Pro 11 Student Edition Question
By MoreThanLuck in forum ComputerReplies: 31Last Post: 10th Jan 2012, 16:21 -
Bluray ripp to lagarith 720x405 resize VirtualDub
By Klemc in forum Video ConversionReplies: 13Last Post: 4th Aug 2010, 00:45 -
what is the fastest software to RIPP into H264 ?
By james_patageul in forum DVD RippingReplies: 8Last Post: 12th Apr 2010, 13:46 -
Vegas Movie Studio+DVD Platinum Edition Menus
By ccarver in forum EditingReplies: 1Last Post: 7th Jun 2007, 19:53
