As a beginner filmmaker should I get the HV40 and start, or is it worth saving up for something substantial like the 5D or something? I've seen footage shot with the HV40 and a 35 mm adaptor and it doesn't look that bad, but I wouldn't know if it's considered good enough for serious filmmaking
Canon 550D/T2I. Around the same price as the HV40. You'll get the short depth of field without the need for one of those clumsy lens adapters. It also will accept lenses from other 35mm cameras (with the correct rings). You'll need more PC processing power to work on the footage of the 550D compared to the HV40.
Good luck. Oh man, you've got so much to learn regardless of which camcorder you buy. One big issue is the need to keep your shots steady. Tripods/Steadicams etc will be part of your leaning curve.
Have a look:
http://www.vimeo.com/groups/eos550d/videos
http://vimeo.com/groups/eos550d/videos/9327798Last edited by Soopafresh; 29th Jul 2010 at 07:32.
"Quality is cool, but don't forget... Content is King!" -
Thank you, it sounds great
Ah, tripods/camera dolly/jibs and all that right? Yeah it seems a bit fiddly, but I'm more worried about all these lenses and lighting since there are so many variations
Canon HV40 not recognized via firewire
By ThanosK in forum Capturing and VCRReplies: 16Last Post: 30th Dec 2012, 09:54 -
canon hv40 test
By foofie131 in forum TestReplies: 1Last Post: 10th Apr 2011, 16:44 -
canon hv40
By foofie131 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2011, 22:01 -
Sony HC3 vs Canon HV40
By alegator in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 25th Jun 2010, 19:19 -
canon hv40 vs hv30/20
By minidv2dvd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Feb 2009, 13:25
