Hi,
I have some .mds (image file) for FAT32 that I need to convert to .mkv file.
Is this possible and which tools allow that ?
Note that the .mds file also has a bunch of IO1, IO2 etc files associated with it.
For a FAT32 system, the image file is .mds and not .iso (for NTFS)
Pls help.
DVD2SVCD 1.1.2.B1 | TMPGEnc | Nero |
I'm guessing you mount with virtual disc software (e.g. virtualclonedrive, daemon tools, alcohol 120, poweriso) , then use makemkv , or if you want to re-encode use something like ripbot264 , staxrip or megui
If you are extracting to storage formatted with fat32, I don't know if your mkv will work or it might be split up if it exceeds filesize limitation
3D mkv file conversion help
By mkv2avi in forum Video ConversionReplies: 4Last Post: 12th Jan 2012, 11:05 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 10:50 -
Help me! I can't play file *.mds file after i 'mount image' using daemon
By i_nui in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2008, 13:04 -
Help with MKV file conversion
By baxterb23 in forum Video ConversionReplies: 31Last Post: 9th Apr 2008, 09:03 -
Fixing .mds disc image
By soundchaser in forum MacReplies: 0Last Post: 9th Sep 2007, 17:37
