  1. Anonymous
    Guest
    Ok this my be dumb question but is the software or is the Hardware that determines your max size? OH! if it software what is the best?
  2. Anonymous
    Guest
    try agin!
    Ok this may be a dumb question but is the Software or is the Hardware that determines your max screen size? OH! if it software what is the best?
  3. What do u mean max size? Do you mean in your display properties? If so its hardware. If not, well explain more. What are you doing?
  4. Anonymous
    Guest
    :lol:
    Thanks. I just wondered if I could use any software to effect my display properties beyond what the hardware says you can have. There are many programs out there that imply that is the software can up your max display properties. I was wondering if that was true.
  5. Well hardware is the root of graphic capabilities. It may be possible to download some piece of software to extend your resolution but maybe you should just buy a new vid card. you can get something nice for about $130. Otherwise check www.downloads.com see if they have any utilities for display tweeking
